Question about American Standard Heating & Cooling
Blows air not cold I don't know how to tell if the compressor is dead or the thermostat
    Problem Solver:
  • 6 Answers
Hook a set of ac guages to the high and low side of your system and see what your pressures are. ballpark low should be 55 psi and ballpark high should be 350 psi. If off replace inline filter on high side, vacuum system and recharge with specified capacity and check pressures again. check to make sure clutch on compressor engages when you turn your ac on. if no charge in system clutch will not engage
Posted on Jul 29, 2009
  • 3 Answers
Simply look outside, is the fan blade spinning? If so it is at least getting a signal to run, next go outside feel for heat rejection in the airstream exiting the condensing unit, feel the suction line at the AC unit,(it's the fatter one) It should be beer can cold and wet!
listen to it, and if you have a meter take an amp draw.
Posted on Nov 24, 2012
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
My air conditoner blows cold for maybe 15 minutes than warm
Are you using a "very powerful" AC to cool off a relatively small space? The AC has a thermostat, if the return air is meeting set point, the compressor would stop. The fan could still be circulating, hence the perception of warm air. What you should do is don't block the ventilation, and direct the cold air toward the ceiling. The cold air will sink (due to higher density) and create better circulation and temperature mixing.
Jul 19, 2011 | Whirlpool Heating & Cooling
My mt 12 cooler doesnt blow cold just warm air
thermostat could not be set properly, compressor could not be running, unit could be low on freon. start checking some items and let me know.
Aug 03, 2009 | Carrier Beverage Air® Marketeer® MT12-1-B...
A/C is not blowing cold air
if the a/c compressor clutch is not engaging, you will never have any cold air. if the system has too much or too little freon in it, that will also mess it up. If system is undercharged, the compressor will short cycle, instead of staying on till the thermostat tells it to disengage. I suspect your problem is in the compressor and that is where i would look first.
Jun 25, 2009 | 1997 Plymouth Grand Voyager
Friedrich a/c zq10 thermostat won't kick in
likely is the thermostat or could be the compressor going out on over load compressor runs blows cold air trips out on the over load fan will stay running jumper out the thermostat see if it stays running.like1/2 hr. if it does replace the thermostat not hard to change if you can find one.Tom
Jun 18, 2009 | Friedrich ZStar ZQ10A Air Conditioner
HVAC issues - A/C blows semi-cold air and Heater won't turn on
hi! there,
there are possible cause in the circuit is the thermostat,since thermostat switch is like a switch of light,when this turn on blower and compressor turn on,if you turn on and no cold your thermostat
is defective.replace thermostat,if run but insufficient cold was feel check the operating current,there is a rated current you can compare it can tell if your freon charged is under charged,this should be done by certified service technician from your service center,have inform from your manual the telephone no. and location have it call.if still under warranty claim it have a nice day.
May 15, 2009 | Heating & Cooling
NO COLD AIR
If the fan and compressor are both running and no cold air then you’re low on refrigerant,
Thermostatic expansion valve closed or bad , dirty condenser or the valves are bad in the
compressor.
Apr 25, 2009 | Haier HWR10XC3 Air Conditioner
Both Fridge and Freezer not blowing cold air.
with the thermostat turned to its coldest setting can you hear or feel the compressor running?  Can you find the defrost timer inside the refrigerator and turn it until the compressor stops, and then please let me know, JT
Oct 24, 2007 | Amana AFD2535DES French Door Refrigerator
Heating & Cooling Logo
442 people viewed this question
Top American Standard Heating & Cooling Experts
Tim Whalen
Mack Baxter
ROCKIT957
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
