Question about Dryers
I have a Fisher & Paykel DG08 gas dryer that will get hot and shut down after 5 minutes. It will not start if you try hitting the start button right away, but will if you wait a few minutes. It did work fine , but have had to start 2 or three times till dry, but now will only run for a few minutes. Inside of dryer seemed extremely hot.
  • huskytown2 Jul 30, 2009
    Tried replacing the L300 thermostat but did no good. this was on the upper right side on the back of the drum.(2 wires a red and yellow). Not sure if is main or safety. Could use a parts diagram or manual. Where can I find one.
    President:
  • 2,559 Answers
The thermal overload is bad and will need to be replaced,This is there to prvent overheating and when it fails and overheating happens,a secondary overload kicks in to prevent a fire.
Posted on Jul 29, 2009
  • Randy Hough
    Randy Hough Jul 29, 2009
    These are also known as high limits
Dryer spins for 10 minutes then shuts off. I have to manually start it again every 10 minutes
Its getting too hot and shutting down to protect its internals.
Make sure the filters are clear of fluff and that the exit vent is not blocked by dirt.
Dec 20, 2013 | Fisher Paykel EcoSmart GWL15
Fisher paykel dryer ed56
Could be the door switch or temp sensor. To check the door switch put pressure against the door and see if it stops. Check the slot the door hits to see if there is anything loose in there.
Jul 20, 2013 | Dryers
I push the start button of the dryer and as soon as I let go the dryer shuts off
Check your motor. DO you have a ohm meter? i would ohm out your start winding of the motor. Its should read resistance. if it shows "OL" then your start winding is bad..i would check this first
Sep 12, 2011 | Fisher and Paykel DG08 Electric Dryer
No heat--only cool air.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./
Mar 31, 2011 | Fisher and Paykel DG08 Electric Dryer
The dryer runs for abiut 5-10 minuts and then shuts down. Then if you wait a little it will start again but repeats the process. What could it be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Fisher and Paykel DG08 Electric Dryer
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Jan 25, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
119 people viewed this question
Top Dryers Experts
