Question about O2 Xda II mini
When opening sound folder the - i  Information pop up says  Waiting.....
The waiting screen freezes and nothing happens , can any one suggest
solution to this problem --  R.Aditya
my o2 ice sound folder not opening its saying waiting waithing not opening plz help plz help
To resolve the problem with "waiting" message when opening images/photos folder is that:
  1. Type: ##1133, then press END (red button);
  2. Select "Photo delete";
  3. Press OK button;
  4. Press END (red button).
WARNING: All your photos and videos will be deleted.
NOTE: On my phone works but now I got a problem with sound folder.
Posted on Nov 30, 2008
0 characters
3 Points
Xda orbit 2 won't start up
sir plz its same problam with me thanks
Aug 11, 2009 | O2 Xda Orbit Smartphone
My O2stealth does not boot! All you see is the O2 welcome screen
Thanks for getting back to me in regards to this matter. I have however solved the problem although all the data was lost.
To solve the problem I read somewhere that you have to turn the phone off, then press the flag button, the OK button, the camera button all at once, then while doing that, you also hold down the on/off button for few seconds. The phone re-boots as new. It was my wife's phone and she is not in the habit of backing up her data; this has taught her a good lesson :)
Once again thank you
Jun 11, 2009 | O2 Xda Stealth Smartphone
My Dopod 900 (aka O2 Xda Exec) White Screen Problem
if you have a lot of data on your phone, do a sync. if it synched properly, if it does, probably the flex is damaged or the screen alone. try to press all the buttons on ur pda phone. if they all make a sound (if your sounds for keys are enabled, i hope) your flex is alright. have your LCD changed. try to tap your screen also if it makes a a sound... Hoping to be of help to you.
Apr 13, 2009 | O2 Xda Atom Exec Smartphone
02 XDA II MIni Speaker
U must have the right tool 2 open ur o2. Then u can start opening ur o2. Once uve opened up ur o2 u can see the speaker at the top. U can see 2 pin at the speaker, u gently pull the pin upwards but dont pull to hard u might break the pin. When both of the pin is pull up u can close back ur o2 . Then u can test whether theres sound coming out of the speaker. If there is sounds that mean uve succeeded repairing ur o2. Bravo........
May 25, 2008 | O2 Xda II mini
front speaker not sound
Feb 24, 2008 | O2 Xda II mini
O2 ice
Hi there mate
have you got it set or have you got a memory card selected by any chance and alsoit sounds like its not communicating with your memory have a technican look at it or Contact this guy Matt hes a pda technian and has msn contact him he will be able to fix it
thank you please remeber to rate me
thank you fix ya
Jan 07, 2008 | O2 Xda II mini
Text messaging
The Same thing happened to me
Go to :
master clear
security code 000000
If not try several times
---------refer to the place where bought..
Jan 01, 2008 | Motorola Mobility A1200
Hi can u help me
Hi there
By the sounds of that it has a corrupted file or a virus in your card best solution is Someone that can fix corrupted files or virus removals message this guy Named Matt they are good with removals and Pdas
thanks and please remeber to rate me
thank you
Nov 23, 2007 | O2 Xda II mini
i have an ice o2 and it just freeze and also the call logs does not work
please help
Oct 19, 2007 | O2 Xda II mini
O2 Ice
o2 ice restart problem
Sep 23, 2007 | O2 Xda II mini
PDAs Logo
192 people viewed this question
Top O2 PDAs Experts
Martin Murray
xxxxxx xxx
Jax Planet
Jax Planet
Are you an O2 PDA Expert? Answer questions, earn points and help others
