J
Joan Buzer Posted on Oct 20, 2017
I have just bought a second hand Olivetti Lettera 25. There is a blank key on the top row to the left of the number 2. What is it for? Thank you.
5 Related Answers
JUSTOLDJIM
James Cagle
  • 482 Answers
  • Posted on Jul 25, 2008
SOURCE: Olivetti Lettera 32 - carriage progression problem
Could be the carriage release lever is jammed or worse the escapement dog is broken.
A
Anonymous
  • Posted on Nov 08, 2008
SOURCE: Number 2 in top left hand corner
hold down hash key for 3 seconds and it will go away
it is something to do with which line you are using,
ewhsajo
  • 4 Answers
  • Posted on Jun 07, 2009
SOURCE: number 2 in the top left hand corner
this is due the fact that your mobile's line is set to line 2
in the ideal screen press # for a few seconds it may solve the problem
Anonymous
  • Posted on Sep 08, 2009
SOURCE: olivetti lettera 22 replacement black/red ribbon ?
i just picked up an olivetti lettera 22 at the local goodwill for $5. it has a ribbon but def. needs replacement. i was on a site that sells them in a 3-pack for $24.00. they fit all standard and portables by olivetti apparently. here it is:
http://mytypewriter.com/b53-olivettistandardandportabletypewriter3pack.aspx
Anonymous
  • 328 Answers
  • Posted on Dec 30, 2009
SOURCE: The Caps Lock/Shift key jammed on my Olivetti Lettera 32
Sounds like the shift key lock spring is broken or missing. Look ont he key and hook it up or find a tiny spring to install.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
How to release margin
The margin release on the Lettera 35 is the last button on the right on the second row of keys . It uses the symbol |<-| on it.
If you are trying to move the margins, there should be two buttons on a scale above the platen (big black paper roller). They should just push down and move to set where you want them.
Broken Platen Knob on Olivetti Lettera 25
Platen knobs are usually held by an Allen screw in the side of the shaft, which can be hard to see and get at, but have a good look.
No ribbon lift
Make sure your cap lock key isn't pushed down. This will disable ribbon shift.
Olivetti Lettera 22 skipping spaces
Thje problem with this machine is that you need to use a fast pecking motion when typing. If you press and linger on the keys for too long this will cause an extra space.
2answers
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
2helpful
2answers
Olivetti lettera 22 replacement black/red ribbon ?
Try Office Depot or one of those big box office supply houses.The Lettera 22 is a pretty old typewriter, but the ribbons ought to be available
Ribbon supply
This ribbon fits many different typewriters 25 and 35 are the same. Spool should be the metal type not the plastic, and you need the nuts on the top....
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
