Noise in color wheel and has actually quit working now
Our son has had some problems with noise for a while and seems to have quit working and says it's the color wheel. Understands there could have been a recall but we are unable to find it. Wants to know if parts are available to fix or if it is worth it.
I do not have a model # as this is the only info we have. I just want to try and help to get this taken care of.
42 # DLP HD Theatre Tv Serial # RC101000500 Made in April '06
Thanks for your help.
Margueritte
    President:
  • 563 Answers
It likely isn't worth fixing because the repair will probably cost a minimum or $200 to $250 and a new 42" LCD at walmart.com is only $578. Do you want to put half of the cost of a new LCD into one that will still be out of warranty after you repair it?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 29, 2009
Samsung dlp tv HLP5663W makes loud noise
Yes, the set uses a color wheel and the lamp faces it.
The wheel turns at over 8,000 rpm and is well known for this problem=bearings in the tiny motor go bad.
The high pitched or fan like noise (classic description) is this part.
Sooner or later the wheel (plastic colored segments) will shatter and set will shut down lamp and not operate---set monitors the speed of the wheel so if it slows down or stops it knows.
The part is readily available on the internet (Google the model number with "color wheel").
This can be a do it yourself repair and You Tube has video instructions for replacing the wheel by model number.
There are two common pitfalls to avoid which the instructions that come with the replacement part usually do not mention---if you decide to do this repair let me know and I will explain.
SD TECH
May 26, 2012 | Televison & Video
Honda Pilot 111,000 miles. Wheel or tire noise?
it can be any of the above, rotate the tires and see if the noise location seems to change, but the last thing i would suspect is the CV, they just click when turning, the wheel bearing is my choice here, they roar, tires make a diff noise.
Jan 29, 2010 | 2003 Honda Pilot
Color wheel or did i break something else?
Usually a bad color wheel will produce a high pitched sound or even a grinding noise; some sets may actually shut down if the wheel is bad or shattered.
To determine if you have a bad color wheel:
  1. Turn set off and wait for main fan to shut off.
  2. Unplug the set.
  3. Remove the lamp door and then remove the lamp.
  4. In the direction the lamp faces you will see a round opening; the color wheel is facing this opening. It is a round plastic wheel with colored segments—we want to look to see if any of the segments are missing; a shattered wheel should be clear to see.
I have also posted the general instructions for Do it yourself replacement of this part in the TIPS AND TRICKS section of this site.
I will attach a photo of the color wheel for you to know what you are looking for----
If you have any questions feel free to respond to this posting.
If this has helped you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Loud humming after turning on.
I have sort of the same problem...there was a loud snap(kind of electical spark like) then the unit started humming loudly which changes sound as you move the unit around. The picture remains clear and the fan is quiet in shut down mode...still the wheel you think?
Sep 07, 2009 | Optoma MovieTime DV10 Multimedia Projector
Loud humming noise when you turn on the TV
There are only two parts in this set that have moving parts and can create noise. One is the color wheel and the other is the fan. There are actually two fans. One you can easily see from the back of the set when you remove the cover and the other is not visible. The most likely cause of this hum is the color wheel. It has bearings and they wear out. You need to be careful when or if you attempt to replace it. There are actually two types of color wheel for this model. Samsung doesn't tell you this. One has air bearings and the other has ball bearings. Mine had ball bearings and I ordered the part I thought was correct. I replaced it and it worked for about at day then failed. I thought maybe I had a defective part and returned the color wheel and ordered another one. Same result. I did some further research and ended up ordering the ball bearing type of color wheel instead of the air bearing type. There is a website that shows you the difference.
This seems to have resolved the issue. Good luck. It's not too difficult to change this color wheel but you do have to dismantle the set a bit and it helps to be somewhat mechanically inclined. make sure to take notes as you take it apart so you remember how to get it back together.
Mel
Jan 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
I Think I have a front wheel bearing problem
yes it has and you need to change it before the wheel flips on you
Jan 20, 2009 | 2003 Kia Sedona
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Noise from tv
I had the same problem with a 5065. I purchased and installed a new color wheel and that solved the noise problem. The color wheel has a bearing that gets "dry", and when it fails it does sound like a fan bearing.
Jul 10, 2008 | Samsung HLN5065W 50" Rear Projection...
52HM95 - Color Wheel noise - and then it stopped ....
I have the same tv and it is making a loud noise coming from a fan I think, and we already went through 3 bulbs, this tv really sucks I will never buy anything from toshiba again
Apr 21, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba #62HM95
I am wondering if this sound might be your color wheel spinning. The color wheel often makes a low humming noise as it spins. Try checking to see if this is not the source of your noise. You need the color wheel to generate the colors needed to turn the B&W picture generated by the DLP into a color picture.
Thank you,
Shuttle83
Nov 08, 2007 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
