Question about Dell Latitude D800 Notebook
How do I tell if I have a stereo sound card (vs. mono), and if I have stereo how do I make it play in stereo (not mono)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 137 Answers
Answers as above are correct, and you can also create an audio test-file and save it, run it through headphones / amp.
Test file can be created with a sound editor such as Audacity, Wavepad, etc.
First create a mono track with lower-frequency sine-wave of say 440 Hz (middle A) of 1 second.
Start a new mono track and create sine wave of say 1000 Hz, also 1 second long.
From about 0.5 sec, highlight BOTH tracks to end and select 'Silence' function.
Select ALL and select 'FADE OUT' function.
Than select a slight tremelo effect. 4Hz tremelo at 50-60% gives a more pleasant 'chime' sound than just a 'beep'.
With ALL still selected, REPEAT about 59 times using repeat function to create a 60 second file.
Now click the pane of second track and select the position slider symbol (Audacity), slide track right until you see peak waveforms are alternate. Left-Right-Left-Right.....
Using balance controls and drop-down menu for each track, make track 1 fully LEFT, and track 2 fully RIGHT.
Looks similar to this:
Track1(L):!!!!__!!!!__!!!!__!!!!__!!!!
Track2(R):__!!!!__!!!!__!!!!__!!!!__!!!!
Click control-pane of track 1 and choose 'MAKE STEREO TRACK'.
Save as MP3, WAV or whatever you prefer.
Name it something like stereo_test.
Posted on Oct 13, 2017
  • 221 Answers
Your laptop should have an Intel AC'97 stereo card.(per Dell specs)
Posted on Jul 29, 2009
  • 162 Answers
Go to your control panel then sounds and audio devices and check your settings
I am only hearing audio out of my left headphone speaker when plugged into the Tascam US-122. how can I play back my tracks and have the audio fill both speakers?
you might be using a mono output jack or input jack.....check the jack end...1 ring = mono / 2 rings = stereo
make sure your sending a stereo signal in, then check the L/R balance.
Jul 06, 2011 | Tascam US122 Audio/MIDI Interface with...
My tascam us144mk2 works great only problem is my headphones only play in left ear i have a pair with 1/8" plug so i bought a 1/4" adapter and only have sound in one ear i've tried multiple...
Double check that the adapter you bought is designed for stereo. The easiest way to check this is count the number of metal bands you can see on the adapter, stereo headphones will have 3 metal bands separated by 2 plastic bands, whereas mono will have 2 metal bands separated by a plastic band.
If you accidentally bought a mono adapter, this will cause sound to only play in one ear.
Mar 06, 2011 | Tascam US-144 Sound Card
Hi... I cannot seem to capture my audio in stereo. The playback from my mic comes from one side (mono) only. How do I set it to play through both speakers? I have 2 input mics...1 one camera and my...
Your microphone has a stereo miniplug, with 3 contacts, that look exactly like headphone minijacks. You have not stated where you are trying to plug this microphone, but most computers /sound cards will accept only mono minijacks, with 2 contacts. Should you have left/ right inputs for microphones, buy a splitter adapter that will turn the stereo jack of the microphone into two mono jacks.
Aug 23, 2010 | Sennheiser (EW100ENGG2C) Professional...
Recording with cubase problem
Need to set it to stereo. There may be a switch on your mixer, and you will also need to change the settings in Cubase to record in stereo, not mono.
Jul 30, 2009 | Lexicon Omega Desktop Recording Studio...
Sound from Hannspree hf199h
you need to plug it into the lime green(if theres one) three outlet audio jacks serve different purposes when their set for mono or stereo
Dec 20, 2008 | Hannspree 19" Widescreen LCD Flat Panel...
Audio from go46
sounds you have 2 channels set on stereo maybe not mono ?
Aug 07, 2008 | Yamaha GO46 Sound Card
42" Sharp Aquous audio; Mono vs. Stereo
no. that is not true. the person you spoke to obviously didn't know what they were talking about. you mean to tell me that everyone that has a cable or satellite box with a stereo or hd tv is not going to receive stereo sound? really,think about it. you only need a cable box( for now ) if you have premium channels (hbo,showtime etc). you can connect the cable line right into the tv if you only have basic cable. look at the back of your cable box. if you have a red, white, & yellow audio/video output, then the box is stereo.connect these outputs to your tv. this connection however is not hd.you will need a hd box with a hdmi cable for hd .To put the tv on stereo mode, there should be a way via the menu and/or the audio button on the remote to get it off mono and put it on stereo. your manual should at least show you around the settings of your tv.
wg
Apr 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sound blaster 5.1 does not support stereo
Cakewalk has it's own control panel to select output buses. Consult the software manual. Also make sure you have the correct ASIO (Audio Stream IN OUT) driver for your sound card. You can most likely find this at www.soundblaster.com -Keep in mind that sound blasters were not made for pro audio applications. Consider investing in a better sound card if you really want to take your music to the next level. Good luck!
Mar 14, 2008 | Creative Labs Sound Blaster Live! 5.1...
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Seems to only play in Mono
Karen - Is it only the FM section that is giging you trouble? Does Stereo work for the other inputs - VCR/DVD/Turntable?
Is that stereo button ONLY for the FM section?
May 13, 2007 | Teac AG-V3050 Receiver
Dell Latitude D800 Notebook Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
