Question about Konica Minolta bizhub 350 All-In-One Laser Printer
HI, i have a C-350 copier. in printing the copy quality is excellent but while copying it is bad, fussy and light.Can you help me to solve this problem. Homi
  • 210 Answers
Clean the LED assy, the cleaning assy and the mirrors in scanner.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Xerox quality gud but when i print from pc then left side of print is faint i will try diffrent frivers for pc
Dear
Try to get print from pa application, i.e. from ms word pp or excel, etc. It some times happen if a scanned image is printed.
as you stated your copy quality is good hence the printing function of the copier is good.
Thanks.
Mar 07, 2015 | Canon Imagerunner 2525
Bad copy quality, prints are good
Could be a faulty optical sensor or crud on the glass?
Jul 24, 2014 | Brother MFC-9840CDW Laser Printer
Imageclass d530 error code e100 0001
Hi, tahta erro indicates a malfunction in the laser unit, probably dirty or defective
Jun 11, 2014 | Canon imageCLASS MF5770 All-In-One Laser...
Some of the letters in printed copy come out uneven
This problem may be caused by several reasons. Bad nozzle pattern,dirty film encoder,etc. Sometimes,perform printhead alignment may solve the problem or else you can set print or copy quality to HIGH.
Simply try to align the printhead or/and set print or copy quality to HIGH.
Recommended source:
Printer Clinic
Dec 12, 2010 | Canon PIXMA MX700 All-In-One InkJet...
My canon ir 5570 print quality not set print quality is very light
lets try first with technical side!
When was, last time, preventive maintenance service?
You need on regular base:
- clean optics ( beneath copy glass too )
- replace charge corona
- replace transfer corona
- clean/replace paper pick-up, feed and separation rollers.
In most cases the problem will be solved with new transfer corona assy.
Jul 06, 2010 | Canon imageRUNNER 5570 Copier
Color looks blauchy. all consumables are at a good level. what I should?
check the fuser rollers for wear also lift the lid and look at the mirrors on the scanner unit to see if there is and dust on them as this affects the copy quality if you are using for printing check the difference in quality if the prints are better the problem is in the glass copy area could be dust or paper dust on mirrors.. if not the drums or transfer could be worn have you had it serviced if not that may be required
Jul 28, 2009 | Minolta bizhub 350 Black and White Copier
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Poor Printer Quality
If you have the old drum put it back in and see what happens to the copy. if is better, then yu may have a bad new drum. They do have them. Poor copy quality is normally drum or toner in these Brothers. This model is an excellent machine by the way.
Jul 22, 2008 | Brother DCP-8040 Copier
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Using Job Accounting with Excel
Try unticking the collate box on the print window. this can cause 50 jobs to be sent rather than 50 copies of the same job.
Hope this helps
Mar 27, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
231 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
