Question about Panasonic Lumix DMC-TZ3 Digital Camera
Shadows Viewing the moitor there are 2 diaginal shadows lower left upper right. The shadows are also on the down load.
Re: shadows
Sounds like your lense cover is not fully retracting when you turn your camera on, thus when the flash goes off these are creating shadows on your picture.
Posted on Dec 18, 2007
0 characters
3 Points
Hello. i jut needed to know where UP ARROWS are located on my camera?
The squarish button surrounding the OK button on the back of the camera is the cursor pad. Push the upper part of it for up, the left part for left, the right part for right, and the lower part for down.
Jul 12, 2011 | Kodak Easyshare C182 12MP Digital Camera
Setting date/time on casio z700
Here is how you do it:
Looking at your watch face: the upper left button is A, upper right is B, lower left is C and lower right is D.
Get your watch into "Hand Setting mode" That is the mode witht he digital time and seconds above it.
From Day and Date window it would mean pushing button "C" six times to get to that mode.
Once in "Hand Setting Mode"
Hold down button "A" til time blinks, then press button "D" to advance the hands, to the desired time.
Press "A" to exit mode.
Press "C" to return to timekeeping mode..
Mar 13, 2011 | Casio Exilim EX-S500 Digital Camera
Canon 1400 IS: When I take a picture using flash of a close up object, a shadow is cast on the lower right corner of the picture. For pictures that are not taken close up with flash, or taken from further...
It's most likely the shadow of the lens. The flash is above and to the left of the lens, so the shadow of the lens will be to the right and below.
Feb 10, 2011 | Digital Cameras
I bought me camera off ebay and the software didn't come with it
Easy, just change the camera's USB connection to the DSC mode. You don't need any software when the camera is in DSC mode, it looks like a memory stick or card reader to your computer.
Enter the picture viewing mode, press the "menu /OK" button, arrow down to menu "2",
arrow down to "Set",
right arrow to the sub menu,
Arrow down to menu "3",
arrow down to "USB",
right arrow and arrow up to change from "Pict Bridge" to "DSC", left arrow out and press "menu/OK" button.
Nov 06, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
How to overlay picture in D40x camera
Overlaying pictures, like almost all photo manipulations, is better done on a computer using "real" software rather than on a camera. You get much more control on a computer. However, the D40 does have a wide repertoire of photo manipulation capabilities.
In order to overlay images, you must be shooting in RAW (or RAW+JPEG). Select Image Overlay from the Retouch menu. A preview dialog will be displayed with Image 1 highlighted. Press OK to get a photo selection dialog. Use left/right to highlight the first picture in the overlay. (You can press and hold the Zoom button to see the selected photo fullscreen.) Press OK to select the image. Optimize exposure for the image by pressing up/down. Press left/right to highlight Image 2. Select the second image the same way. Press left/right to highlight the Preview column. Overlay will show you the result, allowing you to go back and change things if you wish. Save will save the overlaid photo.
The shadow in the lower portion of your camera is probably caused by the lens hood. The solution is simple: remove the lens hood whenever you're using the built-in flash.
Mar 05, 2010 | Nikon D40x Digital Camera
How do I turn the histogram off the screen on my D40x Nikion?
When viewing the picture, Press the multi selector up or down to cycle through the following information:
File Information↔Shooting Data Page 1↔Shooting Data Page 2 ↔ Retouch History (retouched copies only)↔Highlights↔RGB Histogram↔File Information.
The "Multi-selector" is the "arrow" buttons: Up, down, left, right.
Dec 24, 2009 | Digital Cameras
Macro shooting
If you are very close to the subject during macro mode shooting, you will get the shadow of the camera in the picture.
Sep 03, 2009 | Fuji FinePix F30 Digital Camera
When i go 2 photo,s ive taken.then move the shutter button 2 the right 2 zoom in,then it lets me move the picture up down left or right.when ive got the picture i want,how do i save that picture.
Unfortunately that image is not able to be saved that way. To zoom in closer to the image is only for viewing purposes it does not allow you to save the image that way. You would need to download the image to the computer to be able to save it in that close up format.
Feb 24, 2009 | Olympus FE-330 Digital Camera
I have a canon SD110 and can't figure out how to change date. I don't have a manual.
Manual available for viewing/download here. To change the date/time:
1. With camera on, press the Menu button.
2. Use left/right arrows to select Setup menu (icons of tools)
3. Use up/down arrows to select Date/time icon (clock and calendar)
4. Press Set button
5. Use left/right arrows to select year, month, day, hours, minutes and then use up/down arrows to set correct value.
6. When everything is correct, press Set button.
7. Press Menu button to return to normal mode.
Dec 10, 2008 | Digital Cameras
Shadow across photo
Shadows, especially circular shadows, are pretty common with the pop-up flash. What you are seeing is actually the shadow cast by the end of the lens. This happens especially on wider angle shots.
The solution is to find a way to get the lens out of the way of the flash. You can get an external flash, like a 430ex or 580ex, which elevates the flash far above the lens. That is an expensive option so first you might try making a diffuser for your pop up flash, which softens the source of light and helps eliminate some shadows:
Dec 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
172 people viewed this question
Top Panasonic Digital Cameras Experts
Level 1 Expert
Are you a Panasonic Digital Camera Expert? Answer questions, earn points and help others
