Question about Kenmore Washing Machines
Washer sometimes makes a large "bang" noise when it stops spinning
  • 15,935 Answers
This is the clutch engaging to brake the drum.
It is not out of the ordinary depending on the size/weight of the load.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
When spinning on highest spin make very loud noise like brick inside then heard loud bang and noise stopped washer carried on spinning
Hello that sounds like a broken spider that's blotted to the drum what hold the drum to the bearings if one is broken that will do that the banging is when it pop out on a spin it sounds like a brick hitting the back I would be very carefull as it can try and flip the machine if it catch the drum it's not bearings as you said it stopes and it was ok so it's the spider and most drums are sealed units so you can't do any thing ok hope this has helped you
Nov 13, 2015 | Washing Machines
How do I fix a ge top load washer that's making a loud banging noise while agitating?
There is either a balance issue or a damaged spring. Usually all you need to do is open the washer (make sure it is OFF) wait for it to stop spinning... then look for clothes bunching up on one side. Take some out ad move them around.
Sometimes putting in to many or too few items will make it harder to resolve. Items like large towels or several towels, sheets and such will hold more water and be heavy until the water starts to pull out.
Oct 09, 2014 | Washing Machines
Sounds like ametal object in drum but there is nothing visible its making a loud banging noise
hello they usually make this noise sometimes a few thing to check make sure the washer feet are adjusted properly if ok .with the power off you could take the top off see if the 2 springs are attach either side of the washer sometimes the snap or come loose also have a look at the suspension legs make sure there tight or not broken hope it helps
regards
shaun
Mar 27, 2011 | Zanussi ZWF12070 Front Load Washer
On my spin cycle there is a large banging noise. I thought it was due to the fact that the load was too large or collected in one area of the drum but after doing a much smaller load the problem persists....
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Banging while spinning
slid the machine out away from the wall and tilt back enough to see underneath. just below the door there is a large concrete weight. chances are it is loose and needs to be tightened. if this problem has been going on for a while the bolts holding the weight on will have snaped and the drum/weight or both will need replacing . ( ex hoover engineer)
Nov 13, 2007 | Hoover SE230 Front Load Washer
Washing Machines Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
