Question about Cell Phones
I upgraded the music store software and now i cannot access the music store. It power cycles after i press the music button.
How do you access stored radio stations on my gpx hm3817dtblk
To cycle through the saved radio station frequencies, press the Play/Pause/M+ button on the remote or on the HM3817DTBLK. On the remote, this is the middle button in the third row (between the tune/skip/search - and tune/skip/search + buttons). On the music system, this is the third button to the right of the LCD display.
This is described in the manual which is available from the product page: https://gpx.com/in-home/home-music-systems/hm3817dtblk.html . Scroll down and click on Downloads. The manual is the first link. The direct link to the manual is https://gpx.com/amfilerating/file/download/file_id/49096/ . See page 4-5 (page 2 of the PDF).
I hope this helps.
Dec 27, 2016 | GPX Audio Players & Recorders
Tip
SOFTWARE UPGRADE AND POWER SUPPLY CIRCUIT
Software Update
The Software Upgrade menu allows you to upgrade the player's software for performance improvements or additional
services.
• Never turn the player off or back on manually during the update process.
1) In the Home menu, select the Settings, and then press the ENTER button.
2) Select Support, and then press the ENTER button.
3) Select Software Upgrade, and then press the ENTER button.
4) Select one of the following methods:
• By Online
• By Channel
• By USB
• By Disc
• By Downoaded
• Standby Mode Upgrade
5) Press the ENTER button.
FOR MORE CHECK THE FOLLOWING LINK
Electronics Equipment Repair Center
on Feb 14, 2015 | Samsung Bd-E8900 3D Smart Blu-Ray Disc...
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
Can't format my sony walkman mp4
At first reset it by pressing the RESET button with a small pin or similar object. When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
If it is not successful you may make firmware updates for your model. Updates can be found on the Sony Support Web Site: http://esupport.sony.com
The firmware upgrade file is exist and downloadable:
http://esupport.sony.com/US/perl/swu-spec-eula.pl?mdl=NWZE344&upd_id=5491&os_id=7&ULA=YES
gylacz
Mar 28, 2011 | Sony Walkman NWZ-E344 Digital Media Player
Half of the buttons dont work on my phone. how do i fix this?
DIAL *#0000# AND CHECK YOUR SOFTWARE VERSION. IF IT IS OLDER THAN THE VERSION V50.0.005 YOU MUST UPGRADE YOUR PHONE. IN THE OPTIONS MENU PRESS CHECK FOR UPDATES OR UPDATE YOUR SOFTWARE BY USING PC SUITE ON COMPUTER.
May 06, 2010 | Nokia 5800 XpressMusic Smartphone
I have an i900 Omina 8gb touch phone and i have trouble when i touch and want to anything,sometimes i have to tap afew times before it responds,do i need a software upgrade? thanks Andrew
Hello there...
[First]
You could try a Hard Reset.
- Hard Reset: Power cycle your handset while also erase all data, rollback your device to default state (when you got it first time from the store/factory).
How To:
- Hard Reset:
1) Go to Start Menu >> Settings >> System >> Hard Reset >> Clear Memory >> and follow instruction.
2) or other way is: handset in power off state, push small Reset button near the power button while also pressing End & Call button simultaneously and then follow instruction appears on the screen.
[Second]
If that doesn't help try firmware upgrade to latest version.
Latest version for Asia version is DXIA5.
Or check your region latest ROM here:
http://www.samsungmobile.com/support/omnia/index.jsp
[Third]
If that still not helping and you have a spare cash, I think you should consider replacing your Omnia's Touch Panel ^^
Hope that helps....:D
Apr 12, 2010 | Samsung SGH-i900 Omnia Unlocked Cellular...
Itouch will not power off after upgrade to 2..21
Hi cpatrick1717,
if you have updated and restored the firmware, as well as trying the suggested reset from apple. (To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.)
And tried resetting by going to Settings>General>Reset>Reset all settings, and also tried
Settings>General>Reset>Erase all content and settings.
In order to power off, you need to hold the top button down for 6 seconds. Also, try just pressing the top button on and off. If the screen doesn't turn on and off, and you aren't experiencing any other problems, then it may be a hardware fault.
Nathan.
Apr 12, 2009 | Apple iPod touch
Help!
To the op, you might need to switch it back to MSC mode from MTP mode. You might not be able to play the DRM protected music in MSC mode, but you'll be able to access all the rest.  1. With the unit on and not attached to a computer, press the Power/Menu Button briefly once or twice so the menu is shown.
2. Scroll down to Settings then press the OK button (round shaped, centrally located) to enter the submenu, next scroll down to the USB option and press the OK button to enter its submenu, highlight MSC, then press the OK button. After the MSC option is enabled, hold down the power/menu button until the unit shuts itself off. Now plug it back into the computer.
(Now you should be able to find some files to delete. Enter any folders/directories if necessary to find files to delete.)
Unless you have bought and downloaded to your unit protected music from online music stores, you might find it more useful to keep the MSC setting instead of going back to the MTP setting.
To the second poster, you likely downloaded a scam file.  It's sometimes disguised as an mp3 file but it's really likely to be a wma file that has web links that automatically execute when played in Windows Media Player.  Your mp3 player errors when accessing it. Just delete the suspect file(s).
Otherwise you could reformat it or maybe upgrade the firmware. Right-click its icon in My Compter for a popup that allows a format.  Use FAT32.
Sep 01, 2008 | SanDisk Sansa m230 MP3 Player
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
