Question about GE WBSE3120B Top Load Washer
It goes through fill cycle then it stops when its time for the wash cycle and will not work acoulpe of hour.
  • 82 Answers
It can be the heat side of the appliace witch can be ellement, therostat or thermistor u need to get this checked by and expert sould only cost the call out be carefull always ask the price first booking ,some con people saying no call out but then they charge stupid min laubor charges check first
Posted on Jul 29, 2009
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Whirlpool Cabrio washer model WTW6200SW, when the wash cycle is started, starts filling with water, after roughly one minute the machine stops than goes into spin cycle, will spin for a short time than...
Possible there are errors in the program memory. Power off the washer for half an hour, press and hold down the start button , then switch on. Try also with another program. Also check if the inlet filter is clogged and the water flow is good, if not clean. Also check the water level pressure sensor.
Nov 01, 2013 | Washing Machines
My Kenmore Washing Machine Model 110.82872100 goes through the wash cycle then gets to rinse cycle fills with water makes a clicking noise and stops. Does not drain but cycle knob moves. An electrical...
Your motor is getting overheated in wash cycle. if you turn it off for about 15 minutes and start it back up in rinse cycle will it work ? If yes, then motor is overheated. A sign that the motor is over working its self and time for a new motor.
Dec 15, 2010 | Washing Machines
THE WASHING MACHING FILLS WITH WATER, GOES THROUGH
Most Likely it's the timer. try to move it by hand to the net cycle. If that doesn't work it's the contacts on the inside fouling up.
Sep 06, 2009 | Whirlpool Washing Machines
Brand new ultra wash HE stuck in one cycle
Does it fill with HOT water (check after fill stops)? Did Sears install the washer? If so, have them troubleshoot the problem. It's obviously bringing water in. Are there any error lights or codes? May need to replace the control unit.
Jul 14, 2009 | Dishwashers
GE WBSE3120B Top Load Washer Logo
99 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
