Computers & Internet Logo
D
David Posted on Oct 20, 2017
Need to download or upgrade to ios9 or 10 or11
2answers
Kohler 25 hp will try to kick over but acts like a low charge battery. turns over till it hits compression. new battery and starter. ?????
if it has a new battery and starter i would check all connections and check valve clearance. check and be sure you can see the compression release bumping on the valve also. if the compression release is broken you will need a new camshaft. just replaced one a few days ago.
Jul 29, 2018 • HP Garden
2answers
How to get pst my screen lock dell v8 tablet forgot password
Once into the Dell Venue 8 or11's UEFI BIOS, disable Secure boot ... password you got lost and would like to perform password reset on. Click on the Reset Password. -> Restart the tablet and return to the sign-in screen where you won't have to type in a password.
https://www.skypesupports.com/
2answers
What do i need so download or install or do to my 2400 dell deminsion to make it install windows 8.1 version
can you post the service tag number here so that I can check the full specifications of your Dell.?
Upgrading windows vista 64bit
Did you download your Win7 upgrade or did you buy a boxed copy? If you have a boxed version, check in the box. My Win7 upgrade came with both the 32-bit and the 64-bit DVDs in the box. Try using the other optical disk in the upgrade package. If only one disc is in the package, contact the source where you got the upgrade. Only the package for installing a new OS (OEM or full version) comes with just the one disc included. For those, you need to specify the type of system on ordering.
If you downloaded the upgrade, you will need to get a different upgrade file and burn it to disc or make a USB installer for that version of Windows 7.
To confirm your current version of Windows, click Start and choose the Control Panel. Click on System and Security and then on System. This page will display the Windows version and append x64 if you have the 64-bit version.
Alternatively, download the Windows 7 Upgrade Advisor, http://windows.microsoft.com/en-us/windows/downloads/upgrade-advisor , and it will confirm if your system is compatible with Windows 7 and which version you need.
I hope this helps.
(even the Windows 8 upgrade came with both the 32-bit and 64-bit DVDs in the box.)
I have the Point of Sale/Cash Register Heavy Duty RJ-12 Key-Lock Cash Drawer w/Bill & Coin Trays that i ordered of off Amazon. It does not come with software or any instructions. I want to know if i can...
They are supposed to be self installing. If they are not ,its not your fault ,it means either they are faulty or your ports are. On my computer left click and select MANAGE THEN GO TO ports AND IDENTIFY YOUR PORT AS 1 OR11. Good luck
Wireless-G WRT54G Router: how do i upgrade the firmware...
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
SHARP AQUOS WILL NOT PLAY DVD SAYS IT NEED UPGRADE CODE?
Ah, an upgrade. You will need a computer and a disc burner. You need to download the upgrade and burn it to a CD exactly as you are told in the upgrade. Click the link for Sharp firmware.
Most DVDs use a CD to do upgrades. Follow the upgrade detail if this is not so!
2answers
How do I upgrade firmware?
go to linksys download upgrade and follow instructions
2answers
Linksys befw11s4 wireless-b broadband problem
Yes you can upgraded that, you ne3ed to go to http://linksys.com/download and then select the model number of your router and download the firmware and install it, there is also steps on how you upgrade it on the web site
4helpful
3answers
Firmware upgrade
Firmware Upgrade Instructions:
Please download and unzip the firmware file to computer's local hard drive and then follow the instructions in the "readme.txt" file to upgrade the firmware.
Warning : -
Firmware upgrade failure may permanently damage the unit and causing it not to function. If the issues in the "Release Note" do not address the problem you are experiencing, please do not upgrade the firmware. Never upgrade the firmware using a wireless connection. Firmware upgrade will reset the Router to factory default state (all current settings will be replaced by default settings). When necessary, please write down the Router's current settings before performing the firmware upgrade. Please do not load the previously saved Router "configuration file" to the new firmware.
If you need assistance performing the firmware upgrade or if you have any questions, please contact our Techsupport Team http://www.trendnet.com/support.
Grand Canyon Tech
Grand Canyon Tech
