SOURCE: the lid will not lock, therefore the washer will
Hi.
Replace the door lock.
If the door lock is not at fault, then replace wiring harness between door latch and control board.
Enter model number here to find parts and diagrams.
SOURCE: the lid won't lock therefor it won't spin, what
Just had to push down on the lid a little and it locked
SOURCE: My whirlpool won't spin
It ispossible that the machine does not start off the cycle because there are errorsdue to feedback from the inputs. For the program to start up the main programcontroller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting fromthe flow of water into the drum as also the drain valve to open to exit thewater at the point of the program cycle. If this does not happen then thevoltage at the valve/motor/pump must be checked or the fault relates to novoltage from the controller. This meansthe controller is a suspect.If thewater flows then the flow should be good, if not the inlet valve is bad orthere is dirt in the filter. Also check the flow at the inlet of the waterline. Once the water comes into the system the WATER LEVEL SENSOR - normally apressure switch- must activate at the preset/chosen level to give the signal tothe program controller to switch on the motor. What is most important for themotor to start functioning is that the door switch must be ON when the door isshut or this will be an error for starting the motor for rinse and wash.Check thislink to replace the inlet valve:http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html Finallyafter the wash the drain valve will be activated, the water is allowed to comein to rinse and then finally the dry spin with the drain valve/pump activatedso as to drain off all the water from the clothes during the spin.Make surethat a fault in any of the cycle will relate to the specified action, so checkthe command from the program module and then the executing device be it thevalve or motor or pump. Please check the link below:http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
SOURCE: 2003 Audi Cabriolet trunk lid won't close or lock
Trunk lock assemble could just need oiled,try that first and if no help it may need to be replaced.....please rate this post and good luck and hope info helps.
Hi
Thanks
for using FixYa. You can try to jump start the lid switch, if after doing this
it works then it means the lid switch is bad and needs to be replaced. Please
check this video as it provides you step by step instructions that will help
you in lid lock switch replacement:
Please
revert back for more help.
Rylee
