Question about Makita Saws
I cannot get a perfect 45 degree angle with my Makita circular saw. Is it me or the saw??
  • 631 Answers
When using the gauge on your saw it is off on the 45 degree cut? If so you might have to use a tri Square every time you want to cut a 45. Sometimes the lock gauge for the 45 angle may be off some. When you put a tri square on the board you cut it is not a true 45 even though the saw says it is?
Posted on Jul 29, 2009
How to mitre corners
using a set square , The angle if 45 degrees is machined into the handle draw a line at 45 degrees across the surface you wish to mitre cut
clamp a piece of timber along that line and use it as a guide to cut with the circular saw
Apr 27, 2016 | Saws
Bosch Glide Miter Saw get stuck at 45 degree bevel to the left
Adjusting the miter angle involves two cast surfaces sliding against each other. If those surfaces have some irregularities, high spots on the two surfaces will bind against each other. You may have to disassemble the rotating table from the base and do some filing or grinding.
Dec 29, 2013 | Makita Tools 12" Compound Miter Saw -...
How to adjust saw to cut a perfect 90 degree and 45 degree cut
I would go to Makitausa.com and download a manual. what you have aproblem with is either a bent fence or just misalignment. simply all you need is a good square, put the head at 0 degree and check to see if out, making sure not to put square on the teeth of the blade, if it is out there are 4 13mm bolts that hold fence in place loosen them and starting from the left side put it at the exact dead nut. snug the bolt and then check the right side. I usually check them 3 times for accuracy when you are confident snug all the bolts and recheck. Let me know if you need more assistance
Jan 19, 2011 | Makita 10" Dual Slide Compound Miter Saw...
Which bolts do i loosen to adjust the 45% angle of my blade? Ive already squared up my blade by using a square and laid it down on the deck and squared the back rail like that> but how do i square...
To adjust the bevel, (blade angle), loosen the black lever at the back of the unit, tilt the blade housing using the handle (this may require a fair bit of force) until the arrow on the scale is at 45 degrees then tighten the black lever.
Dec 26, 2010 | Makita LS1214F 15 Amp 12 Inch Dual Bevel...
It doesn't give me a precise 45 degree cut
the fence might be bent or needs to be squared up. how is the 0 degree. If you need to find out how to square this tool go to Makitatool.com and type in your model number and you can download a user manual with the instructions on how to do this, let me know I work on them every day. Good luck
Jan 20, 2010 | Makita 10" Dual Slide Compound Miter Saw...
45 degree cut
loosen the miter lock, tilt the table to 45 deg. tighten the miter lock
Feb 19, 2009 | Makita 7 1/4" Circular Saw 5007NB
I have a makita mitre saw and need to adjust the angle to 45 degrees. I unlock it and try to turn it but it won't turn. Any ideas?
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Dec 13, 2008 | Makita 10" Dual Bevel Sliding Compound...
45 degree cut
Are you having problems with the miter or bevel ? Are you asking how to physically move the saw to that degree angle?
Nov 17, 2008 | Makita 10" Dual Slide Compound Miter Saw...
Saws Logo
226 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
