Mitsubishi ws65513 rear projection tv not powering up
The unit will not power up, front panel led continually blinks. i had a tech come in and i was told that the signal/deflector module was defective, he checked the power supply and said it was good, was he "snowing" me?
i looked at the module and besides removing a few screws and disconnecting a few ribbon cable connectors, it looks like a simple r & r process. if the diagnosis is accurate, where can i buy or have rebuilt this module? and once replaced, are there any adjustments that need to be made?
  • 2 more comments
  • Sherry9 Nov 26, 2007
    We have a Mitsubishi WS-55613 55" rear projection tv which was working fine until this weekend. Turned it on and the only thing that happens is the green light on front continues to blink. We have tried unplugging and starting over, and also using the reset button. Nothing helps. Any suggestions would be appreciated. We tried to access the Chris & Nat site, but were unsuccessful.
  • Abelardo Dec 02, 2007
    As you stated, I replaced the 4 caps in the DM module, the only concern was the original caps were 1000mf 16v vs. the 100mf 25v which was recommended and I installed, Is there a cause to be concerned? I also cleaned the lenses and mirrors, and TV picture looks great! Thank you for your advice!
    Yes, my mistake, they were 1000mf 25v caps, i thought that the 25v would be an upgrade, Thank you so much for your help, the tv looks/works awesome! Just in time for the football games!
    It's been about 10 yrs. since i've done any component repair/ replacement ( I was a data systems tech. in the navy) it took a little while longer than i remember it should, but once i got into it, it wasn't too bad to do. Again thank you very much for your help!
Thanks I was able to solve the Blinking problem on my Mitsubishi TV (ws65613). The instructions are easy to follow. Only, I had to be very cautious to desolder and solder the capacitors. Chris, thanks again.
Posted on Nov 05, 2008
  • 1,694 Answers
I have fixed three DM modules in the last 10 days........good thing you are getting a second opinion ! Change four caps in
DM module 1000mf/25v details available @..........
Posted on Nov 23, 2007
  • 1 more comment
  • Vista Electronics Dec 02, 2007
    Great report ! .............Hopefully you installed 1000mf....not100..
    As to the voltage rating...25v is recommended to improve reliability ....common practice for knowledgable technicians....
    16v would be minimum voltage rating in this case.............T.
    Sorry the ChrisandNat site didn't help....the solution is as posted
    to bigjune62..requires above average technical skill....I can give
    you basic step-by-step if you wish.....let me know........T.
  • Vista Electronics Dec 03, 2007
    Way ta go ! ............................I ,too, am X-Navy .....
    blackshoe ET 1968-1972.....been fixin' TV's 72-present...T.out..
  • Vista Electronics Dec 07, 2007
    Please follow up with Fixya rating.....thanks.....T.
Mitsubishi rear projection tv when plugged in power led blinks 3 times then when i switch it on remains powered for about 2 seconds before switching back off again...
DO THE SELF CHECK THIS SET HAS: WHEN POWER LIGHT GOES OUT-----ON FRONT OF SET PRESS AND HOLD BOTH THE MENU AND INPUT BUTTONS FOR AT LEAST 5 SECONDS AND RELEASE BOTH BUTTONS. The power light will blink a two digit error code like: 2 blinks, 2 blinks, a pause and then repeat the code several times. Let me know what error code you find and I will tell you what it means. IF this told you something you did not know rate this solution as very helpful as I do this here for free. SD TECH
Sep 07, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Power outage tv never came back on
Unplug connector zn under front speaker panel if it comes on with remote replace this part. If fails to come check DM caopacitors generally also cause this problem
Feb 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Blinking green light on front of ws55909 projection tv. have reset it by both unplugging and pushing reset button. light continues to flash. has for 2 days. can't operate tv
do this press and hold device and menu button on the front of set.. this is to retrieve a to digit error code flashed by the leds. also this set neds to "boot" let the led flash for at least 70 seconds. if it continues to blink the tv failed to boot. There is service bulliteens that states capacitors in power supply can be bad. this capacitors are kinda hard to get to and rather invovled to replace
Jan 15, 2009 | Mitsubishi WS-55909 55" Rear Projection...
if the timer led keeps blinking (more than 2 minutes) the DM module needs to be fix:
if doesn't respond after been blinking, bottoms on the front panel leaky
Nov 01, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Continual blinking green light
Thats a very common problem and very easy to fix. If your model is the WS65513 you need the Kit called V23 DM repair kit. You can get it at the following link which includes the parts and the Instruction CD that documents the repair step by step with pictures. Its listed under the repair kit category. Heres the link.
Aug 08, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi Mod # WS-55315
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Mar 13, 2008 | Mitsubishi WS-55315 55" Rear Projection...
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V,
105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with
part # 181P734030 (680 uFD, 16V, 105C).
I have done one of these repairs and they are quite difficult so have a tech do this repair.
Feb 14, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
482 people viewed this question
Top Televison & Video Experts
