Question about Goodman CKL60AR60 Air Conditioner
GSC130241AE Goodman Air conditioner does not restart
My unit is only in its 3rd summer. The AC doesn't turn on when the temp increases over the set temp only the fan works. If I turn it off and then back on after awhile, it starts to cool again. What could it be?
  • 286 Answers
It could be a bad thermostat.When the unit isnt working does the tubing frostup? If you have heavy frost in the evaporator this could mean a leak or a dirty coil. Also make sure the filter is clean.
Posted on Jul 29, 2009
Goodman AC unit recently service but don't believe the filter I am using is the issue or what the tech did actually fixed my issue. Details below.
Setting the air handler to high speed will draw more current and this will result in an increase in electricity consumption.
Jul 27, 2017 | Goodman Heating & Cooling
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
I have an goodman model # gsc130241ae ac unit outside it will not come on, no hum, fan doesn't run thermostat control is good swaped out with downstairs unit. Gas heat unit is in the attic, I don't use...
Does the blower indoors run and move air? if not it would mean that you don't have power to the furnace.
The 24 volt transformer in the furnace is used to power the thermostat and the control circuit on the A/C unit outdoors. Or you could have blown a fuse on the computer board in the furnace.
If this has helped please rate me, and If you need more help, give me some more info.
Thanks,
Paul
Apr 02, 2010 | Goodman CLQ36AR49 Air Conditioner
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman fan running but no air coming out of vents and temp is now 85. Also, is there a restart button on the machine
you have to chaeck if the outdoor unit is running you the t-stat has to call for cooling in turning closing contacts between r and y the pulling in coil at condensor. your outdoor unit is not running
Aug 17, 2009 | Goodman CLQ36AR49 Air Conditioner
I just moved into a brand new home that has cental air (Goodman air conditoner) how do I turn on?
turn the thermostat to cool and turn the temperature down if it still doesn"t run check for double pole breakers that are off
Jun 30, 2009 | Goodman CKL60AR60 Air Conditioner
Hello, We bought a Perry Home in Georgetown TX last March and it is still under its two year warranty. Our air conditioner stopped cooling today. It has been working well for over 1 year. We came home...
You have a 10 year warranty on your AC. Call a Goodman rep and have it serviced. It will probably be a bad compressor capacitor. Bad wire or no refrigerant.
Jun 26, 2009 | Goodman Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
385 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
