Question about Whirlpool LEW0050P Electric Dryer
My dryer is making a loud clunking sound with each rotation. When I look in the drum on the back center of it I see about 6 rivet that seem to be connecting the drum to something in the back. The holes that the rivets are positioned in seem to be bigger than the rivets. Out of the 6 it looks like 4 are not properly secured in the holes and each time the drum rotates it sounds like the rivets are thumping in and out of place or just grinding against the holes. I am wondering if I should force the 2 remaining rivets out of the holes or if all of them are actually supposed to be there. What is the solution to the loud sound? Thanks. Whirlpool LEW 0050PQ
  • 631 Answers
It could be that your rollers are wore out and let the drum fall down. If you stick your hands inside of the drum can you lift it up with your hands like maybe the drum is down lower then it should be? And do this while not running of course. lol See if there is any slop in the drum with your hand lifting up and down on the drum. See if you can also pull it forward any.
Posted on Jul 29, 2009
Loud whine and clunk when the drum rotates
Without knowing the model, generally this is the bearing in the center of the drum
at the back. They are around 20 dollars online and usually the whine is the metal
housing that surrounds it, rubbing metal to metal. The model and serial number
to locate the part should be inside the door of the dryer. Hope this helps
Jun 01, 2011 | Dryers
When the dryer is on it makes a loud clunking sound during each rotation
Check to see if something was left in a pocket when dried and fell out. like a coin, a magnet, a wrench. Often, things fall out of pockets and make a loud clunking sound when the drier is turned on.
Feb 05, 2011 | Dryers
Loud clunking noise from drum when rotating
hi just go to this site
http://whirlpool.custhelp.com/app/answers/detail/a_id/2991/kw/loud%20clunking%20noise%20from%20drum%20when/p/256/sort/null,null/r_id/108281
you will find your answers
May 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Heavy Duty Plus "old Dryer" making a loud clunking noise, still heats and dries?
that sound is a bad drum wheel,the drum has 2 back wheels that the drum rides on
May 03, 2010 | Kenmore Dryers
My White Knight sensordry tumbledryer has been making a loud banging noise, (like there are shoes banging about). Is it a bearing problem? Is it a problem that i can fix?
sounds like the bearing carrier has come away from the drum-same as mine,seems to part of the drum
so not available seperately-its riveted on not bolted,mine has deformed and enlarged the rivet holes in the drum so a repair dosent seem practicle if yours hasnt chewed itself up then you may be able to replace the rivets with nuts and bolts and maybe change the bushing kit for about 6 quid
Jan 31, 2010 | GE Profile DPSB619ED Electric Dryer
Dryer makes a clunking noise while drying. Is it possible that the drum is "Out of balance"?
Most likely if it is a thump thump noise a drum roller has a flat spot and is causing the noise.
The dryer will operate ok but it will be loud.
A service call may be needed to replace all 4 drum rollers.
Jan 06, 2010 | LG DLE2532W Electric Dryer
Drum in Frigidaire GLTF1240AS0 has loud clunking noise
The rear drum support must be replaced.The supporting ball has eaten into the support cup.The belt will have stretched and must be replaced also. You can do the job yourself.
Aug 18, 2009 | Frigidaire GLTR1670A Front Load Washer
Dryer Making Lound Wobbling Noise
I'll bet the drum is cracked.
Jan 11, 2009 | Dryers
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
Drum makes a clunking sound when rotating, even when empty
This machine has roller wheels in the front that are not adjustable, but rather need to be replaced if they have a bad spot or something. Usually what I see with a clunking noise(clunks once or maybe two quick clunks in succession) is that the dryer has been set down hard on the ground and has put two dents in the roller surface of the drum. To check this, just unplug it, pop the top off (3 screws in the back and tilt it up) and look at the very front edge of the drum. rotate the drum by hand (carefully so you dont pop off the belt) and look for any imperfections in the suface, such as dents. If you are getting more of a vibration type of noise, I would also suggest taking off the lower front cover then taking of the blower wheel cover located to the left side and checking that there is no lint built up in the blower wheel as well. Good Luck!
Dec 11, 2006 | Asko T781 Electric Dryer
Whirlpool LEW0050P Electric Dryer Logo
134 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
