Question about Weber Grilling
Just bought a Weber Genesis II LX Model S-340 Natural Gas Grill. The plumber installed a 54' line, 1" in diameter. The grill will only heat up,to 400 degrees. What could be wrong?.
    New Friend:
  • 20 Answers
If he really installed a 54 foot line instead of a 54 inch line, the line is way to lone. The gas pressure isn't high enough to supply enough gas to the grill to get any hotter.
Posted on Oct 23, 2017
  • 36 Answers
SOURCE: i have weber genesis 3
When you switched it out did you contact www.weber.com
to see if this can be done on this grill. Weber is different than a lot of other grills usually their larger models they can be converted but their smaller models can not. This might be something you need to check with the company.
I know with Weber that it doesn't consist of change out the hose and a orifice they also change out the manifold.. So please check with Weber for these answers.
Thank you,
Fireplace-girl
Posted on Apr 26, 2008
SOURCE: Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Posted on Jul 18, 2008
  • 512 Answers
SOURCE: Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Posted on Jan 20, 2010
greg_margo
  • 1959 Answers
SOURCE: Can a weber spirit e210 natural gas grill be
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Posted on Apr 27, 2011
SOURCE: low/weak flame on Weber Genesis Silver B Grill.
Simple solution but probably the correct answer is: Turn on the tank SLOWLY before you open any valves on the BBQ. Once the tank is on fully, close the tank and open again, slowly. Then open your BBQ valve and start as usual. The Tanks need backpressure in order to open fully. This is a safety feature to avoid opening a tank with nothing attached.
Posted on Apr 07, 2012
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 | Grilling
I have a genesis model 320 natural gas grill what
change all the gas orffices and the reg , try Calgary bbq center for a kit they are on line .
Sep 07, 2011 | Weber Genesis E-320
Bought a brand weber sprit grill from home depot. Used 4 times. Won't go above 350
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101 ';';
Aug 11, 2011 | Weber Genesis Silver B Grill
I have Weber Genisi Silver model 8133 which has been hook up to a natural gas line. We have moved to a new location and can only use a propane tank hook up. Do I need a adaption for conversion to...
Unfortunately, you cannot use your Natural Gas Grill on Propane Gas. In addition, there is no conversion kit for Weber Grills. That's why they make two different gas models. Conversion of a grill becomes a safety issue. As each model Weber grill is tested and approved only for the specific gas type. Attempts to convert it voids that approval.
I'm sorry I didn't have better news. Thanks for choosing FixYa.
Jul 27, 2011 | Weber Genesis Silver B Grill
I have a weber genesis grill. It did not heat up above 425 degrees at first and now it does not go above 300. This is with the searer on as well. Does this make sense to you? It is hooked up to a...
Was your grill originally set up for Natural Gas or did to convert it from Propane to Natural Gas? If so, where did you get the conversion kit? It may have been missing some vital parts.
If it was not a conversion, did the grill come with a natural gas regulator already installed?
Please advise... Thanks
Jul 18, 2011 | Weber Genesis Silver B Grill
I need to convert my weber genesis b to nat. gas. Have the hose. bought a replacement manifold part and installed but doesnt seem to work. STEVE 269-600-8111
Steve, you also need to change the burner(s) orifices to Natural Gas orifices. Natural gas won't work with Propane orifices.
Good luck and Happy Grilling!!
May 14, 2011 | Weber Genesis Silver B Grill
What is the NATURAL gas flow rating CFM for a Weber Genesis S-330 grill at 60,000 BTU max? I will be using 1/2" black pipe 40ft long run to the grill off a 3/4" main line - ok? Thanks...Dennis
Dennis, it's not the CFM you need to know, it's the water column inch that is required. In this case it's 7 inches. Also, if you're burying this 40' run, you can't use black iron pipe. A less labor intensive and perhaps less expensive way to go is 1/2" Flexible Copper Refrigerant Tubing. It's comes in 50' & 100 ' roles from your local home center. Even if you're not burying the line, it's a better way to go, as you'll have fewer fittings that could be prone to leaking. I
n addition, you'll also need and an inline gas shut off valve at the connection before the grill and a 12' long quick disconnect gas hose, that connects to the copper pipe connection at the shut off valve and then to the grill. This is a code requirement.
Now, with all this said, I hope you have a Genesis S-330 Natural Gas Grill. Because, the Genesis Propane Grills ARE NOT convertible to Natural Gas. And Genesis Natural Grills ARE NOT convertible to Propane.
Hope all this helped you make the right decisions. Have a great day and Happy Grilling!
Apr 13, 2011 | Weber Grilling
Weber gas grill won't heat above 325
You problem could be or probably is with the regulator...not enough gas pressure...
heatman101
Sep 04, 2010 | Weber Genesis Silver A Grill
Genesis GE310 Gas Grill: I just installed a full propane tank on my Weber, ...
Maybe just clearing air out of the line, other than a minute would not be normal.
May 18, 2010 | Weber Genesis GE310 Gas Grill
Grilling Logo
311 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
