Question about Compaq 430186-001 - HP Pavilion dv8000 Series 8x DVD±RW Dual Format Double Layer Burner with Lightscribe La... Burner
Laptop beeps but will not turn on. screen stays
Laptop beeps but will not turn on. screen stays off, sounds like it is powering up but will not turn on. Takes over 100 attempts to get it to finally power up properly and operate. I can no longer reboot or turn off my computer for risk of it not turning on again.
  • 71 Answers
Symptom sounds like a memory module came loose, worse there may be a crack on *********** board. Re seat RAM, or take it in to be serviced. Dead or low CMOS battery may also exhibit this symptom.
Posted on Jul 29, 2009
Powers on but no video
Guessing HP? Sounds like your video. Chip is cooked. New motherboard is required
Nov 16, 2013 | Computers & Internet
Tip
Dell Laptops (Has power no display issues) 1. Immediately run PSA. (Make sure...
1. Immediately run PSA. (Make sure laptop is connected to AC Adapter. Leave laptop off. Press and hold on the Fn key then press power button once).
2. Just wait for about 3 to 5 minutes then you might will hear beeping sounds (no display with beeping sounds) this means that laptop is working fine but no display. This might cause by either the video card or LCD.
3. After hearing beeps turn off laptop. (Press and hold on the power button for about 3 seconds)
4. Leave laptop off. Press and hold on the D key then press power button once. If full screen colors appears this means LCD is working fine and the problem is the video card. If no display from the LCD no colors were displayed try the test again just to make sure. If still the same no full screen colors then the problem is the LCD.
on Dec 03, 2009 | Computers & Internet
Computer will turn on but will not boot up
Dear,
Did this situation come with any beep sound. Because, most of the time, in this situation; the computer beeps. Here are some codes. Check if any of these condition apply to your system.
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals
One Beep Everything is normal and Computer POSTed fine
Two Beeps POST/CMOS Error
One Long Beep, One Short Beep Motherboard Problem
One Long Beep, Two Short Beeps Video Problem
One Long Beep, Three Short Beeps Video Problem
Three Long Beeps Keyboard Error
Repeated Long Beeps Memory Error
Continuous Hi-Lo Beeps CPU Overheating
best of luck!
Mar 07, 2012 | Gateway 510XL (2800446) PC Desktop
My t23 powers up screen stays black and has 3or4 beeps
I think you will find the battery is the cause of the problem, replace it.
Feb 15, 2012 | IBM ThinkPad T23 Notebook
Sounds like start, but screen stays dark,
Not even beeping? Hard to tell from such little info. HDD doesn't work, CPU stays cold, that would indicate a motherboard problem, but then it would beep most of the times. It can be a a problem with your screen, but that doesn't add upp with the HDD, and the CPU staying cool (bye the way, how do you know that?)
I think you should take it to someone who can take a closer look on it.
Jun 11, 2009 | Computers & Internet
Power supply doesn't turn off completely and 3 beeps sound coming
HI,
it seems that your Laptop encountered a VGA problem.
try to reformat your laptop it is the best solution in your problem.
thanks,
Mar 16, 2009 | HP Computers & Internet
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Compaq 430186-001 - HP Pavilion dv8000 Series 8x DVD±RW Dual Format Double Layer Burner with Lightscribe La... Burner Logo
299 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
