Question about Philips Magnavox 42MF521D/37 Television
Magnavox model 32MF23ID/37 42" LCD TV need a power cord
    President:
  • 563 Answers
Fox International is Philips' parts distributor. Please call 800-321-6993 to order the power cord you need.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 29, 2009
    Problem Solver:
  • 4 Answers
Just use a core from a old comouter it is the same thing
Posted on Aug 24, 2009
Magnavox 32MF301B/F7 32 in. LCD TV - my TV turns on by itself. What can I do about that?
Is it in a location that allows the sun to shine directly on it? Sometimes the light can trick the infrared sensor for the remote. Also, does the TV have any self timers enabled?
Feb 24, 2015 | Magnavox 32MF301B/F7 32 in. LCD TV
Magnavox 32mf23id/37
The video you inserted here shows nothing but a blank screen. Its back-light inverter board should be checked. There is no back-light now. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.
Apr 28, 2013 | Televison & Video
Power will not stay on , on my magnavox tv model 32mf337b/27 unplugged like user manual suggested but didnt work even after 30 hrs saw on magnavox.com a few people have had same proble with this model mine...
Magnavox has issues with puffed caps on the power supply. This sounds like its a 32 inch lcd tv. I tried searching for a service manual for this and can't find one. If it is an lcd you need to look at the capacitors on the power supply. If they are puffed up, you will need to replace them with equal or slightly larger valued capacitors. The capacitor values are mfd and voltage printed on the capacitors themselves. You will need a soldering iron to replace them. Lay the tv, if it is an lcd, on a flat surface cushioned by a blanket. Make sure the surface is large enough to support the tv frame, as you don't want to cause damage to the panel. remove the back of the tv. There are numerous screws, and once the back is off, check the power supply pcb for puffed caps. This is the board with the power cord attached. I know in magnavox tv there is a cage covering the power supply, so remove any connectors because you will have to flip the cage housing the power supply to get to the caps. If you feel confident, give it a try. Let me know how it goes
Apr 03, 2011 | Televison & Video
Where do I purchase a power cord for a magnavox 15mf605t/17
its the same as a computer power cable you can find these all over the place. try ebay
thanks
michael
Mar 25, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
I NEED A POWER SUPPLY AND CORD FOR A MAGNAVOX 15' LCD TV MODEL NUMBER 15MF400T/37 POWER RATING 12V 3.5A
Either you can get this universal type available inthe market in any electronic spares store or it is easy too make one by yourself if you are familiar with electroncis.
All you need is a mains transformer with secondary voltage at 12 volt and 4 amps capacity, use a bridge rectifier , good storage capacitor of about 4700mfd/25 volts and if possible use a 12 V regulator so that the power is smooth, regulated and protected..
Sep 24, 2010 | Philips Magnavox 15MF400T 15 in. LCD...
Magnavox 37MF331D 37 in. LCD TV tv will not come on, power light blinks. I tried disconnecting power cord and hold power button to discharge, still will not come on and as soon as I apply power again the...
I had the same problem with a Magnavox LCD TV. It would not turn on and the light on the external PSU flashed. I found a replacement 12V 5A power supply on EBAY. It brought the set back to life.
Sep 12, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Where is the r3340 resistor located in the magnovox 32mf23id tv
In the service manual where any professional television servicer would look. If you are not a technician why try to do their job? Is your time worth nothing?
May 04, 2009 | SNK Magnavox 32MF338B27 32 in. LCD TV
Magnavox HDTV very dim
hi i have a philips 42 pfl5522d and need a new screen can you get me one..
Mar 16, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
32mf23id philips
Sounds like the internal power supply is going bad. Loses power to the tuner first then the whole tv.
May 09, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox 15 inch lcd hdtv
the typical power cord is usually the same kind that is plugged into your monitor right in front of you. Buy another one of those. A universal remote should work (not promising anything)
Feb 12, 2008 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 42MF521D/37 Television Logo
581 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
