Question about Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0
How to format the hard drive of a laptop without a battery
I was one of the unlucky multitude who ended up with a Dell Inspiron B130 laptop. At this point, I really need to wipe the drive and set it back to where it began. Data has been removed, I have device drivers and I'm all ready to go. The problem is that you can't format the hard drive of a laptop unless it has a battery.
The battery that came with this died in the first year. This machine has always been awful...so slow and difficult. I will not spend money on a new battery. But without it, I can't reformat it.
Is there anything I can do to make this work? Thanks in advance for your help.
  • Lori Engelbrecht
    Lori Engelbrecht Jul 29, 2009
    When asked if this answer helped, I chose "No." Then I was asked if this was related in any way to my problem and I answered "Yes." Then it said "Thank you, you have rated this as Somewhat Helpful!" Too funny!
    I can run the laptop with A/C power. But I cannot restore the laptop without a battery. I boot it from the restore CD and I get a message that says the battery needs to be connected to run the restore. It looks like this is a pretty common problem, but I just wanted to see if someone had a solution for it.
    Scholar:
  • 122 Answers
It should run with the bad battery in if AC power is connected. Then just run the restore cd. Good Luck
Posted on Jul 29, 2009
Dell inspiron b130 Laptop
Try to remove the battery, turn the wifi switch off just connect it to the power socket and try to turn it on again, if this does not work, I think you need to take it to pc hospital
Jun 02, 2017 | Dell Inspiron B130 Pentium M 1.7ghz...
I have no problems..need larger hard drive for Dell Inspiron B130. Have only 15gb left. Is this a diffucult task? hump
Surprisingly the task of replacing the hard drive is fairly easy, as soon as you have purchased a replacement drive (make sure it's a IDE 2.5ins drive)
Just click on the link that i have provided bellow for instructions on how to remove the hard drive from the laptop and replace it >>>>
http://www.mrdimpy.co.uk/Dell%20Inspiron%201300%20Service%20Manual/hdd.htm
Regards.
Jan 06, 2010 | Dell Inspiron B130 Notebook
Is there any way to format a laptop without a battery?I have a hp compaq.the problem is i tried to format it and install a new operating system in it. but after formating and copying all the necessary...
After you format the drive you need to go to DOS and load DOS with CDROM support, then launch Windows through the command prompt
D:\I836\winnt.exe
the D may be another drive letter, but that should start your install.
Good Luck
Mark
Dec 28, 2009 | Dell Inspiron B120 B130 1300 / Latitude...
What size of hard drive to use dell inspiron b130
hi,
As standard it comes with a 60GB Hard Drive (5400RPM)
The following link will give you a idea of what the spec is and the performance of the laptop.
http://www.notebookreview.com/default.asp?newsID=2732
Regards
Gewiz.
Dec 10, 2009 | Dell Inspiron B130 Notebook
Need to knouterw how to wipe the hard drive clean
Download GParted and burn it onto a CD. Reboot and boot from the CD. Follow the instructions.
Sep 17, 2009 | Dell Inspiron B130 Notebook
Inspiron B130 shuts down after about 5 seconds
Sounds like a bad AC adapter not charging the system. If a known good adapter has the same issue (Or this adapter works on another system) then it is a motherboard replacement
Sep 14, 2009 | Dell Inspiron B130 Notebook
I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 28, 2009 | Dell Inspiron B130 Notebook
Upgrading dell inspiron b130
A replacement computer is likely cheaper than the parts
Oct 19, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron B130 Laptop
email me at meanness628@aim.com i am not on here every day i need more information on this problem
Sep 29, 2008 | Dell Inspiron B130 Notebook
Dell Inspiron B130 wont boot
First remove the battery from the PC! Leave it off for a short period of time! about 2min. This allows the computer to erase anything in temporary memory. Place the battery back onto th PC and try to boot it up. The other thing you can do is boot the pc up with just the power cord in place. See if it boots just from the power cord. Sometime the batteries from dell causes the whole entire PC to become unresponsive.
Nov 26, 2007 | Dell Inspiron B130 Notebook
Dell Inspiron B120 B130 1300 / Latitude 120L Motherboard - RJ273 - GG0  Logo
306 people viewed this question
Alun Cox
