Question about Epson Office Equipment & Supplies
I need to change a printer cartridge that the printer doesn't recognize as out of ink? It won't let me get to the other printer cartridge!
  • 555 Answers
In order for your printer to recognize the installed printer cartridge you have to buy a cartridge that is exact match to your Printer recommended by the manufacturer. Also avoid to buy not genuine cartridge to avoid the same problem as you have. Also do not try to inject your printer cartridge by your own ink to prevent the cartridge from damaging and might have possible damage on your Printer as well.
Thanks
Posted on Jul 29, 2009
Epson artisan 1430 won't recognize ink cartridges
press ink change button and while printer is checking if ink is ok press and hold power button for 10 second (it won't shut down the printer) and let go. then it will shut down by its self. turn it back on and printer will go through some checking (more then usual) and then it will see all ink cartridges. If that won't help your cartridge is not genuine.
Mar 06, 2013 | Epson Artisan 1430 Inkjet Printer
Canon printer won't recognize new ink cartridge
did you take the shipping tape off of the cartridge? It's usually the one covering the contacts located on the underside of the Cartridge that is inserted into the receiver of the cartridge. Other wise, you may have a bad cartridge, if so, bring it back to where you purchased it and get another one. Chris Chrisab123@live.com
Feb 28, 2012 | Canon PIXMA MP160 All-In-One InkJet...
I have a canon IP 4200 printer. The ink cartridge light on the Magenta ink cartridge doesn't work so it won't accept/recognize that a new ink cartridge has been installed. Is this something that...
It sounds as though you have a break in the carriage ribbon cable. A new carriage would hopefully cure it but its just possible the logic board has failed and is not sending any signal to the magenta ink tank. Its certainly repairable but you would need to know the costs and the labour charge to see if its worthwhile.
Aug 27, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
I have a Canon iP6700D. I refill my carts. I have a resetter and use it every time. This time the printer won't recognize the magenta cart. I refilled it, reset it and replaced it as always. I...
If your printer did not good in times of reseting the cartridges do check the cartridge holder if the is some dirt inside or the terminal of your cartridge had wet by the ink when you refill the ink of your cartridges.
Aug 12, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
The check print cartridge light is on and won't go off even after changing both ink cartridges
This could be a number of problems. Depending on the printer and ink, you may have to power cycle it (turn it off and then back on after a minute). Many printers nowadays also have you do an alignment page. You may want to attempt to do an alignment page if your printer has that functionality built in. If that doesn't work, as silly as it sounds, check to make sure both ink cartridges are locked into place securely, even if you need to remove them and put them back in.
Aug 04, 2011 | Office Equipment & Supplies
Brother mfc 5540cnz wont recognize ink
To rectify this error with your printer,
first of all, you need to snap the cartridge in and out a few times.
If this doesn't work, you need to remove the printer cartridge from the printer and then clean off the foil contacts.
You need to be careful while doing this and do not wipe the nozzles from where the ink comes out.
Insert the cartridge and switch on the printer. Now your problem might be fixed.
Get more information to fix cartridge not recognized problem .
Hope this information helps you.
Jul 28, 2011 | Office Equipment & Supplies
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Canon ink is not being recognized by printer
To rectify cartridge not recognized error with your printer, first of all, you need to snap the cartridge in and out a few times. If
You need to be careful while doing this and do not wipe the nozzles from where the ink comes out. Insert the
cartridge and switch on the printer. Now your problem might be fixed. If this does not work, it is better to inform
the manufacturer or contact online technical support experts.
May 05, 2011 | Canon Office Equipment & Supplies
When I install non brand printer ink in my Canon MP 460 printer the printer doesn t recognize the full cartridge I just installed
Canon printers and cartridges have their own chip that recognized the presence of original ink, either the ink you bought is not compatible or the printer need to be reset
Jul 19, 2009 | Office Equipment & Supplies
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
