SOURCE: I have a john deere 4110 tractor with a 261
Hello. These mowers have a soft metal pin which breaks rather than break an expensive part. Check to see if you have broken a pin in the power takeoff or in the mower. J.
SOURCE: My John deere LT 160
Check the blades, I expect that you will find that they are wearing out.
SOURCE: HOW do i level my lawnmower to cut grass evenly on my john deere 17 hp gt275
YOUR MANUAL SHOULD TELL YOU.
If it is the belt driven version you should have a deck belt and a drive belt. The drive belt is under the engine. If you have the hydraulic version check for a broken linkage at the pump.
SOURCE: John Deere x300 runs for about 30 minutes then stalls. There is no gas in the filter.
Check your fuel cap to make sure it is venting properly. If a vacuum is being created, and no air is able to get into the fuel tank, it will prevent the fuel from reaching the carburetor.
