1990 Yamaha XJ 600 Logo
Posted on Jul 29, 2009
Whats the best and easiest way to set the carbs on a 1990 yamaha radian yx600
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jul 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
4190
Points
13
Your problem is probably the sycronizing as long as you havent messed with the fuel screw or jetting. If you dont have a set of vacuum guages you can eyeball the slides in the carbs to at least get you by and you can usually get them pretty close. Find the carb that is directly linked to the cable. the other carbs are adjustable to that carb so you need to make all the other carbs identical to that one. Look at the gap from the bottom of the slide to the bottom of the bore of the carb on that base carb with the throttle at idle bike not running. With the adjustments on the linkage to the other carbs adjust the other slides to the same height as that base carb as close as you can. Measure if possible to get all the carbs as close as possible to each other. you may have to adjust the idle after. If the adjustments on the carbs are all cables, for example there is a cable to each carb directly connected to the slide just adjust each cable accordingly and achieve the same as above. make sure you have a little freeplay at the throttle when you are done. you can adjust that by the cable adjustment by the throttle which will keep all the carbs in sync
Radian idles high at 4 g then drops down to 21/2 g then dies
Your Radian has 4 Mikuni carbs. If just one has a stuck float or one set incorrectly it will overflow with gas and run out. The bike will run poorly if at all. You need to pull all the carbs and clean them thoroughly. Check you r fuel line too for leaks and cracks. Make sure your air filter is clean and the boot going to the carbs from the airbox. Check the boots on both sides of the carbs for cracks. Air leaks can cause the idle issues you describe but you have to fix the overflowing carbs first which might fix all of it. Make sure you have a nice large work area, don't lose the small jets or strip the bolts. This answer is directly for your issue you have presented. Good luck!
2helpful
1989 Radian YX600. I can start it by slightly
how do i clean my 1989 radian 600 yamaha carb
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
