Question about Dryers
Dryer motor will not start
Timer, start button and door switch all seem to be working correctly but motor acts like it is not getting power. Checked power up to the pluggable drive motor switch and getting 120 v on both big red wires before switch but not after switch, not sure if this means anything or not...
  • 4 more comments
  • johnny_sizem Jul 29, 2009
    Whirlpool Model# LER7648KQ0, I also found a thermal cutout fuse that Im not getting any continuity through (light blue wire)
    Whirlpool Model# LER7648KQ0, I also found a thermal cutout fuse inline of a light blue wire going to the motor that is not reading any continuity. Not sure if this helps.
  • Mike Smith
    Mike Smith May 11, 2010
    brand and model number necessary to help
  • Cool Blue Services
    Cool Blue Services May 11, 2010
    Need more info: Your Make and Model number should always be included with your issue, especially if it is a electrically related issue.
  • leanos325 May 11, 2010
    what is the model number of the dryer? What brand is it?
    Scholar:
  • 76 Answers
Did you check the push to start button for continuity? i tried pulling up a wire diagram for that model. but every one ull up i cant read what color wiring it is because it to small of a print, but i can see the rest if the components fine. The wire diagram that i pulled up shows a thermo fuse inline with the motor. That is also in line with a belt switch. By any chance, did you see a belt switch down there? Its should be a little switch by the pulley. if so, check that. If you do have a belt switch, make sure your belt isnt broken. which probably isnt because you would of noticed that right of the bat. But yeah, i think i see the fuse your talkin about that is inline with the motor. Hopefully the wire diagram that i keep pulling up is that dryer you have. You said that fuse is reading "OL" on your meter when its set on ohms right? If it is change the it out. If it reads 0.0 ohms, that fuse is good. I like to use the ohms setteting on my meter when checking stuff like that out. But yeah, like i said if your dryer has a belt switch down there check it out also. If your belt is in tact, just unplug the wires to the belt switch and ohm it out, should be 0.0 ohms for good switch. But if your belt is broken(which i dont think its not) you would have to pull the switch up and ohm it. (Like if you had belt tension around pully.) But yeah, check the push to start switch, check that fuse again, and check the belt switch(if its down there by the idler pully) 0.0 homs for good switchs, "OL" for bad for bad ones. I know i typed alot. sorry for this long story. But hope this helps..let me no what happens...
Posted on Jul 30, 2009
  • Dryers Master
  • 1,525 Answers
Hello at the side of the motor is a part called capacitor it might be white in colour the are 2 wire coming of it this could be the trouble good luck
shaun
Posted on Jul 29, 2009
Electric dryer not turning on.
Check the thermal limiter fuse near the dryer motor.
Mar 05, 2017 | Maytag PYE2300AY Electric Dryer
HI, my dryer stopped working, check belt it not broken and in place. So what can it be. Can it be the starter button?
Hello there and thanks for choosing fixya
Investigate these areas if your dryer is not starting:
Proper Voltage from the House
Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
dryer_door-switch.jpg Door Switch
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it.
dryer_start-switch.jpg Start Switch
A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again.
dryer_thermal-fuse.jpg Thermal Fuse
A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
dryer_thermostat.jpg Thermostat
A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
dryer_timer.jpg Timer Motor
Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly.
dryer_motor.jpg Motor
A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
Jan 23, 2011 | Dryers
Motor not running.
Make sure the door is fully closed. The door switch or the start button is most likely bad, but other part failures could also produce the same symtoms: thermostat, thermal fuse, motor centrifugal switch, etc.
Apr 06, 2010 | Whirlpool LER5636P Electric Dryer
The Dryer stop working. The Start button doesn't
You need to check to see it you have power coming out of the timer? There should be a wiring diagram inside the control panel.
Door switch should be checked with the timer set to run and start switch pressed down to start. Check for power at the motor see wiring diagram for which terminals.
If you give me the model # so I can look it up I can try to walk you through it.
Mar 22, 2010 | Maytag Dryers
Wont start, power to all parts, is there a reset button?
There is a wiring diagram on the access panel on the back, or in the control head.
Follow the path from incoming power through all switches and leading to the timer.
I suspect either the door switch or start switch has failed.
Jan 27, 2009 | Whirlpool LER5636P Electric Dryer
Dryer does not run
The time my electric dryer acted like that, it turned out my door switch had gone bad.
Jan 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
391 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
