Same problem with a Vivitar X029. Take out the battery, then try to push the memory card further down into the slot. Replace the battery and close the door.
The camera is not seeing your new memory card, the memory full is referring to the cameras own internal memory. go into the menu and try to find the function that changes your memory from camera to the card.
I have bought new Samsung S3310 mobile. I want to ask that, how to change the default memory to memory card because when I transfer any file through bluetooth it pop ups that phone memory is full please delete something. My memory card is 1 GB. Please help me to solve this problem
You may have a defective memory card. Have you tried it in a different device? Do you have a card reader on your printer or computer? If so, try inserting the card and see if your computer can read the card, and write files to the card.
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
The following memory cards are compatible with your Kodak EasyShare C330 Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your Kodak EasyShare C330 accepts SD Card cards.The largest SD Card card you can use in your Kodak EasyShare C330 is 1GB
Is it telling you the the card specifically is full or just full. Some cameras need to be switched from onboard memory to memory card. Also, if you are using a high capacity memory card make sure your camera can take a hgih memory card. If you put a 2 or 4 gb card in and it says full that means your camera can't use those cards.
