I have an E2, or 34, or F4 error codes on a air conditioner
I have an E2, or 34, or F4 error codes on a Friedrich AC model SS10. What does it mean?
SOURCE: e2 CODE ON SUNBEAM SCK14200DR
I just fixed this on mine one minute ago.
Take off the front panel.
You will see a black wire held onto the heat fins by a plastic clip.
This is the thermocouple that measures temperature.
Mine became unplugged from the circuit board and plugging it back in fixed the problem.
The wire goes into a steel box.
take off the screws on the bottom of the box, grab it by the lowed left corner and bend the metal up as far as you can.
The wire plugs into a small white connector on the circuit board.
plug it back in, bend the metal back down, screw it in, replace the cover, and you should be good to go.
-Alexander W MacFarlane IV Ph.D.
Posted on Jun 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: E2 error code on Haier cprd12xh7 portable air conditioner
Hi! You need to check pump filter. It could be jammed with a coin or hair clip. Now take the machine outside and empty it then lay it on its side and you can access the pump. Take it off, stand up the machine and pour hot water into the soap draw and check water should run out of bottom freely taking any fluff or bits with it. Now take apart the pump and clean it and dry all components before re-assembly. If the machine still doesn?t work then you need to replace the pump. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Posted on Jun 13, 2009
  • 1078 Answers
SOURCE: what does the code E9 mean,on a friedrich air
Go to http://www.friedrich.com/ and browse this site. You should look at the top for "Support and Downloads." There are lots of manuals there.
Good luck and hope this gets it for you.
Posted on Jun 27, 2009
6ylucy
  • 742 Answers
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
Posted on Jun 26, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
I have a Friedrich QuietMaster Electronic SS12J30D Air Conditioner and I got an E9 error, what does it mean?
E9 is the code for heat pump failure. If you can locate your reset button, reset the unit. If it doesn't work, you might want to consider getting another unit
Aug 08, 2016 | Friedrich Heating & Cooling
When the indoor unit is on F4 fault error code display.please help to solve the problem.
f4 mean Air Conditioners Questions & Answers - Fixya
www.fixya.com > Forum > Tags > f4 mean
My gree split type ac error F4 what is problem Name of malfunction = Outdoor tube sensor open or short circuit Display of double eight code = F4 this means
Oct 29, 2015 | Heating & Cooling
What does error code f4 mean?
What type of unit and model/serial #?
May 15, 2015 | Heating & Cooling
On a Friedrich in wall AC/Heater in the heat mode in the digital display while the unit is working fine I get a flashing 08 alternating with the temp of 74. Model # PDE15K5SB-A is this a trouble code
This is an error code for "Unit cycles more than 9 times per hour". The service manual says the possible causes are "Unit oversized" and "Low load conditions".
Jan 10, 2015 | Friedrich Heating & Cooling
Friedrich cp24g30a code of ch 34
Friedrich Room Air Conditioner Service & Parts Manual 2014-2015
CP15 & CP18 & CP24
ERROR CODE
CH34 High Pressure Error Fault Codes -- As high pressure,comp off over 10 times in 1 hour
UPDATE: 9/24/17 -- So, after multiple plot twists with the particular AC that kept giving us this error message and shutting off, we finally got to the bottom of the situation. This model is supposed to be a WINDOW and WALL capable AC. We had it inside a wall sleeve (proper size), but apparrently it was not vented properly. (Of course, we did not know that for nearly 4 years.) To keep this story clear, I am going to refer to two ACs:0 "Bob AC" the unit with heat and "Stanley AC" the unit without heat.
When we first bought "BOB AC", it failed within 1 month --and out of desperation, we pulled it from its wall sleeve and put it in a different location but in a window sleeve. We put "Stanley AC" which was in another location in "Bob AC's" wall sleeve.
We have 4 of these ACs in our offices, -- but this new one "BOB AC" was the only one that also has HEAT. But, BTU and size-wise all our ACs are the same. But while "Stanley AC" -- the non-heat AC did not have that same error message and "worked" in the wall sleeve, it also did not really cool our showroom. And, they would just up and die one day. (Yes that means there was more than 1 Stanley that we killed.) So during the hottest week in this summer, "Stanley AC", the CP24g30 that we put in that wall sleeve where "BOB AC" used to be - suddenly up and died -- and because "BOB AC" had been working amazingly well in its window sleeve, I moved "BOB AC" back into the wall sleeve where it originally failed. And, as you might expect -- "BOB AC" failed within 2 hours of installation.
Now, we had all sorts of theories as to why the Bob and Stanley ACs failed. One of my team was certain the failure was caused from the AC being in direct sunlight. I didn't agree, but when "BOB AC" was in a different spot, it was out of direct sunlight. (I did find info on direct sunlight -- it will impair an AC's efficiency, but it should not cause this failure.) My believed the problem was based on our neighbor building having a large HVAC pointing its exhaust directly at our AC's vent. We thought this hot exhaust was overpowering our AC's ability to vent, it so we installed sheetmetal to block the other buildings exhaust from going into our AC. Ironically this sheetmetal solution may have been the reason that "Stanley AC" died. Anyhow I kept researching and finally I came across an install instruction which talked about wall thickness and how much of the AC needs to be exposed for proper venting. When "BOB AC" was installed in a window -- only 3" of the face of the AC was inside the room and the remaining 24" of sleeve and AC were outside the window...but when both "Bob and Stanley AC" were installed in the Wall sleeve, it was very different -- probably 9" inside the showroom, then the wall, and then the back-end of the AC. Essentially and bottom line, we had installed the sleeve incorrectly and the ACs were baking themselves to *****. They were NOT venting properly at all. After a lot of debate with my trusted handyman, we pulled the AC and he wrestled with the sleeve and pulled it our 9 more inches. We reinserted the AC -- and now: 1) NO MORE ERROR MESSAGES; 2) NO MORE INSTANT SHUTOFF and even more amazingly - -3) "Bob AC" is working PERFECTLY and the room is now decently cooled by it...and when we had "Stanley AC" in the same spot, while it did not fail the same way or as quickly -- it also did not cool the room. Had we known we were not venting it correctly, poor Stanley might have lived a long, happy life and kept us cool.
Hope this long story helps others. Good luck.
Jul 11, 2014 | Friedrich Chill CP24G30A 23500 BTU Window...
I'm looking for the accordian style panels for the friedrich qstar 06j10
Hello, here is a link to parts for your AC. http://www.searspartsdirect.com/partsdirect/part-model/Friedrich-Parts/Room-air-conditioner-Parts/Model-SQ06J10BA/3120/0904032/50024048/00002
Jun 20, 2011 | Friedrich QStar SQ06J10 Air Conditioner
I have an AC unit with the model # PDH12K3SD-C the unit stops working and flashes an error cod = "06" anyone know what the error code means?
According to the Owner's Manual if the Error Code flashes "06" the O.D. coil Temperature > 175 Deg
F for 2 consecutive minutes. (Heat Pump models only).
The action taken by the unit is Alternate flash set point and error code. Shut unit down for 5 minutes, then try again 2 times, if fails the 3rd time, then shut down unit.:
All of this is can caused by several things:
• Dirty filters
• Dirty coil
• Fan motor failure
• Restricted air flow
• Improper refrigerant charge
• Restriction in refrigerant circuit
The dirty filters, dirty coil and restricted air flow you can troubleshoot and solve yourself. The reaming ones should be handled by a an authorized service technician.
Here's a link to your Owners Manual, that you can download and print for future reference.
http://www.ajmadison.com/ajmadison/itemdocs/92008705_9-07_PTAC_IO_manual.pdf
Hope this helped to to troubleshoot and solve the problem . Please let me know. Thanks.
Jun 10, 2011 | Friedrich PDH12K3SD Air Conditioner
Got error code e9 on freidrick ac
e-9 Unit cycles(Heat or cold) 3 times per hour.Unit undersized /High load conditions.Fix higher capacity of the unit.
Jul 20, 2010 | Friedrich QuietMaster Electronic SS12J30D...
Heating & Cooling Logo
362 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
