Question about HP Scanjet 8390 Flatbed Scanner
Power supply died and replaced. Now get error code
Power supply died and replaced. Now I get error code 05 followed by "processing" and then "Ready" on the scanner.
When I try to use the scanner from the PC, the scanner is not found but in the PC device manager all is well. ??
I've checked power, drivers, USB connections and still no luck. I hate to discard a $1000 + scanner. Any ideas would be appreciated.
OS = Vista Ultimate
  • rhr32568 Jul 29, 2009
    Thanks Rockitman
    I'm not where I can do as you propose but last night I did a fresh install on another PC and got the same result so I think it must be something else. Any other ideas?
  • rhr32568 Jul 30, 2009
    When I look through the glass, it looks ok but I'll try your suggestion when I figure out how to get the top off. I have all the screws out except under the contol panel but I can't get the contol panel off. I would like some help here. I tried to find a service manual but had no luck there. Do you know what Error code 05 is?
    President:
  • 2,185 Answers
Hello there.
You might need to reinstall the driver installation of your scanner if you still have the cd installer. If not anymore, you can give me the scanner model and brand and we'll try to find a driver for you.
Posted on Jul 31, 2009
    President:
  • 2,559 Answers
Go into the device manager and uninstall it,then unplug the usb and plug it back in,let windows find it and it will reinstall the drivers and it should be fine.
Posted on Jul 29, 2009
  • Randy Hough
    Randy Hough Jul 29, 2009
    If you had the same problem on another pc then the scanner is out of alignment,if you remove the cover and gently slide it all the back to it's normal resting position,it may reset and start working again.
Why is my kodak 5250 showing error code 3807?
Error: "System status failed" (3807) Published 08/25/2010 11:38 AM ' Updated 08/28/2012 05:23 PM ' Answer ID 1249
How do I resolve the error message "System status failed" (error code 3807)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
  1. Open the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error is resolved, upgrade your printer firmware:
  1. Locate and select the firmware for your printer.
  2. Follow the on-screen instructions to install the firmware.
If the error is not resolved, contact us.
Jul 01, 2014 | Kodak ESP 5250 All-in-One Printer
I get a error 05 code on my precor treadmill C932/C964
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
Apr 05, 2014 | Precor 932i Treadmill
Corrective Action
Precor EFX 546 05 stuck key
Corrective Action
Jul 02, 2013 | Precor EFX 546i Elliptical Version 4
Printing is always blair and i cant view what is printer
Here is a full story
HP LaserJet Professional M1130/M1210 MFP - Interpret control-panel light patterns (M1130 Series only) Interpret control-panel light patterns (M1130 Series only) If the product requires attention, an error code appears on the control-panel display. Status-light legend c01993382.gif Symbol for "light off" c01993383.gif Symbol for "light on" c01993381.gif Symbol for "light blinking" Control-panel light patterns Light status Error code State of the product Action All lights are off.
c01993373.gif The product is turned off. Press the power button to turn on the product. Ready and attention lights blink.
c01993380.gif The status lights cycle during the formatter initialization period or when the product is processing a cleaning page. No action is required. Wait for the initialization period to end. The product should enter the ready state when the initialization period is finished. Ready light is on.
c01993421.gif The product is in the ready state. No action is required. The product is ready to receive a print job. Ready light is blinking.
c01993420.gif The product is receiving or processing data. No action is required. The product is receiving or processing a print job. Ready light is blinking slowly.
c01993420.gif The product is in low power mode. No action is required. Attention light is blinking.
c01993418.gif E0 Paper is jammed in the product. Clear the jam. E1 The input tray is empty. Load the tray. E2 A door is open Verify that the print-cartridge door is fully closed. E4 The product memory is full The job is too complex for the product to print. Simplify the job, or divide it into multiple files. E5 The product did not pick up paper from the tray. You might need to clean or replace the pickup roller. H0 The product is in manual-feed mode. Load the correct paper type and size into the input tray. H1 The product is processing a manual duplex job. Load the pages into the input tray to print the second sides. The attention and toner lights are blinking.
c01993375.gif E3 The print cartridge is missing or is not installed correctly. Install the print cartridge. The toner light is on.
c01993429.gif The print cartridge has reached the end of its estimated useful life. When the supply has reached this condition, the HP Premium Protection warranty for that supply has ended. You do not need to replace the print cartridge at this time unless print quality is no longer acceptable. Attention light is blinking, and ready light is on.
c01993379.gif The product has experienced a continual error from which it will recover on its own. If the recovery is successful, the product continues to the processing data state and completes the job.
If the recovery is unsuccessful, the product continues to the continuable error state. Try removing any media from the media path and turning the product power off, and then on again. The attention and ready lights are on.
c01993388.gif E6
E7
E8
E9 The product has experienced a fatal error from which it cannot recover.
  1. Turn off the product or disconnect the power cord from the product.
  2. Wait 30 seconds, and then turn on the product or reconnect the power cord to the product.
  3. Wait for the product to initialize.
If the error persists, contact HP customer support
Mar 01, 2013 | HP LASERJET PRO M1132 MFP
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Error code 05 appeared on screen. We have tried to reset. Hit stop, enter, & quickstart buttons as decscribed. We also tried the reset button. The error code remains. We unplugged and tried again, but...
Corrective Action
Apr 11, 2011 | Precor 933 Premium Series Treadmill
Error code 5
Corrective Action
Aug 11, 2010 | Precor EFX 546i Elliptical Version 4
Error f2 in copier ar 5127
F2:
00:TONER SENSOR
02:TONER SUPPLY PROBLEM
04:WRONG COUNTRY,WRONG CARTRIDGE,DRUM
05:DRUM PROBLEM,WRONG CARTRIDGE
39:PROCESS UNIT THERMISTOR PROBLEMS
58:PROCESS HUMIDITY SENSOR PROBLEM
Sep 25, 2008 | Office Equipment & Supplies
49 people viewed this question
Seeker5211
Seeker5211
