Question about HP Photosmart C7250 All-In-One Thermal Printer
Last line or two of print gets cut off
I have the same problem with my HP Photosmart C7250 printer. The last line or two often are cut off when printing from Word. Doesn't anyone have a solution?
    President:
  • HP Master
  • 566 Answers
I have seen this suggested in a HP Support Forum. See if it solves your problem:
1. Go to your printers folder, right-click on (the network connected) printer that you are having the problem with and select "Properties"
2. When the properties window opens, click on the "Ports" tab.
3. Near the bottom of the Ports tab window is a check box for "Enable bidirectional support", uncheck it and click "OK"
Posted on Jul 29, 2009
Hp photosmart C7250 hangs while printing
Hi Georgette,
You have tried your best with possible troubleshooting to fix the issue. There are few possible workaround solution for this issue.
First, If the USB Cable is more than 3-5 ft long, it could be the reason. Also, if the USB Cable is worn out or is broken in-between.
2nd, The printer does not seems to accept command from PC ( win 7 ) using the HP Software. So Uninstall the Software. Restart the PC.
Do not install Printer Software. Connect the Printer USB to PC and Windows 7 will display new hardware detected message.
Continue with the New Hardware Found Wizard and install the drivers it will list by Default.
Try to print and it should work.
If this works, You will be able to print without any problems however if you want to scan a document, you need to use Applications like MS-Paint, Microsoft Word etc, or Use the Scanners and Camera option in Control panel.
You can then install the software disk of printer or the downloaded software from Hp website to install Printer software for SCanning.
If you do so, you will find 2 printer icons in Printers Folder. First one will be with WSD text ( this icon is created when you connect the printer using USB without installing the printer software ) and 2nd icon will be HP Photosmart C7200 All in One ( this will be the Software installed ) and this will be default icon with check mark.
Whenever you want to print from any application, You need to click on File - Print - choose the WSD icon to print.
Regards,
Sean S
Sep 19, 2012 | HP Photosmart C7250 All-In-One Thermal...
HP Photosmart C7250 lines in photos
Replace print heads.. For draft or letter work you can adjust with this print heads, but photo prints you need good healthy conditioned print heads.. as per you info you did every thing rest only thing to replace..
Jan 09, 2012 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 w Vista PC inserts a blank page between every printed pg
You have told it to print a "seperator page"
your hp software has this setting and you need to turn it off
Aug 22, 2009 | HP Photosmart C7250 All-In-One Thermal...
HP C7250 AIO won't print wirelessly from my laptop
Do Add Port in Printer Properties Ports tab and choose Standard TCP/IP. Enter IP address of the printer and follow steps to finish configuration.
Hope this helps!
-michan-
Jul 20, 2009 | HP Photosmart C7250 All-In-One Thermal...
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Last line getting cut off when printing
go to control panel and click on printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see this website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Mar 31, 2009 | HP Photosmart C7250 All-In-One Thermal...
Blank sheet before each printed page
Here's a simple solution. It's easy! Instead of it being the C7280 - it's the C7250 - should be the same driver however. Good Luck!
Aug 02, 2008 | HP Photosmart C7280 Laser Printer
HP Photosmart C7250 All-In-One Thermal Printer Logo
396 people viewed this question
Seeker5211
Seeker5211
