Question about Refrigerators
It makes ice but ice will not dispence through the door
    President:
  • 2,559 Answers
The ice actuator in the door is not working,This will require removal of the ice/water dispenser section.
Posted on Jul 29, 2009
Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
Sep 21, 2014 | GE Refrigerators
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Whirlpool side by side
Hi, it sounds like you have a bad auger motor on your dispencer. If the button works for water, usually it will work for ice. It is also possible that you have a bad dispencer control board. If you would provide me your model # I could assist you further.
Dec 02, 2008 | Refrigerators
LG wont dispence ice
hi there,
sounds like you have ice in the ice bucket. it's most likely that the ice paddle is jammed or broken. check around the ice door and paddle for anything visibly broken as well. you may have to replace the ice paddle.
Sep 30, 2008 | LG LFC25760 French Door Refrigerator
GE 23.5 CU FT side by side w/ice maker and water in the door.
replace the dispenser control under the front panel on the freezer door if need detaild instuction after receiving parts reply to me
Jan 15, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
