Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Chamberlain Garage Opener not working
My garage door opener will not work. Might it be an overload switch? If so, what can i do about that?
    President:
  • 3,197 Answers
If it is not working at all and no lights are lit then check the power source. Try plugging a lamp or small radio into the outlet.
Posted on Jul 29, 2009
Sears troubleshooting
craftsman garage door openers are made by chamberlain.. Give them a call on their 800 number with your craftsman model number and they will help you
Aug 23, 2014 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Replaced logic board on my Sears garage door opener and still getting 5 blinking lights and not working. sensors seem ok.
The opener is flashing the code for "RPM sensor or motor overload." Try unplugging the opener for about 15 minutes and see if the memory will reset.
Aug 18, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door senser not working
What doesn't the sensor do with an obstacle?
Feb 27, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not close from remote or car. Garage door will open from remote or car; however, it will not close using these controls. The only way I can close the garage door is to press on the manual...
Try reprograming the opener to each remote, if this doesn't work then the command/radio module in the opener is damaged and needs to be replaced. Hopefully you can find one or you will have to replace the whole garage door opener. Good luck.
Jan 21, 2012 | liftmaster Chamberlain Garage Door Opener...
The wired keypad (Chamberlain) of my garage door is not working. The red light on the keypad keeps blinking. Can someone tell me how to fix that? FYI, the garage opener, the remote, and the wall unit all...
You can try programming the keypad using the procedure below.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Mar 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Chamberlain garage door opener works fine except when the sun is shining, then it acts like something is blocking the sensor. How can I make the door opener work in the daytime?
There are a couple easy solutions for this. You can try switching the sensors side to side or use the cardboard tube that comes inside toilet tissue to shade the lens.
Dec 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have Chamberlain LiftMaster 1255R garage door opener. The electric eye does not lit and the opener unit flashes 5 times and then off. Do you know what the problem may be?
My garagedoor opener is not working.
I open the box and found the plastic gear worn out.
I have Liftmaster 1255R.
Do I need to replace the whole box or replace the worn gears?
Jul 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need dip switch settings for Sears remote 139.53778
MATHCH WITH THE CODE ON THE BACK PANEL OFTHE OPENER AND THEY SHOULD WORK
Mar 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
131 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
