Question about Dell Computers & Internet
RAM i went to staples and they took a diagnostic test and said that my computer needs a new ram, since i dont know anything about computers is this true? first they charged me 75$ for the diagnostic test now they want more $104 to replace my ram
  • 2,229 Answers
I have no idea what test they ran or why you took the machine to them.
Was it having a problem?
Assuming that the RAM tested bad, you can easily replace it yourself. If you are not willing to do that then I suppose you'll have to have them do it or have someone else do it.
There is no way we can really answer your question, as we know nothing about the original problem or what tests were run.
Posted on Jul 29, 2009
ASUS Computer
Activate S.M.A.R.T. at bios is not active
Do a Hard Drive diagnostics
Think You Might Have Hard Drive Problem Test it for Free
Test your RAM with Windows Memory Diagnostic tool
Test your RAM with Windows Memory Diagnostic tool CNET
Backup your data while you can
then to at CMD: chkdsk c: /F
Sometimes repairs bad HD sectrs.
If you have serious Hard Drive problem, you should replace it.
Now, somehow I suspect your problems could be RAM memory.
May 24, 2015 | ASUS Computers & Internet
Increase RAM to 4 mb for my Sony PCG-252L computer. Went to a another site this morning and they say the machine will support only 2 mb, 1 mb X 2. What is the truth?
I think you mean 4Gb instead of Mb...and you have 2 slots for your RAM...each supports up to 2Gb for a total of up to 4Gb...that's what the x 2 means...'times' or 'by' 2...you have to or should, increase both slots with the same amount of RAM at the same time...it will not support 4Gb in only 1 slot...Hope I helped!
Jan 13, 2015 | Sony Computers & Internet
Bought 1G ram from local computer store. It runs for about 5 minutes then i get a blue screen error and reboot. returned to store for a different mem stick...same issue. went to Crucial, found the...
Did you remove the "old" RAM, or did you add the "new" RAM to the old RAM?
Try using your computer with ONLY the "new" RAM installed.
Try using your computer with ONLY the "old" RAM installed.
Try using your computer with the "new" RAM in the 1st slot, and the "old" RAM in the 2nd slot.
Try using your computer with the "old" RAM in the 1st slot, and the "new" RAM in the 2nd slot.
Aug 27, 2010 | HP Pavilion ZV5220US (PF143UA) PC Notebook
I am getting memory read/write error. Try to reseat the ram.
If reseating the ram does not work, there may be an issue with the ram installed. Did you upgrade the ram yourself? You may have the wrong type of ram installed.
If you have the correct ram installed, then you should run diagnostics on the ram to be sure it is functioning correctly.
Download Dell diagnostics for your system from Dell at the following website:
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=-1&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=INS_PNT_PM_1525&hidos=WLH&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Click on the diagnostics tab and then choose "Download".
Reboot the computer and press the F12 key when the Dell screen appears. This will prompt the boot menu, use the arrow keys to select "Dell Diagnostics" and press enter. Press Tab until "Test System" is highlighted and press enter. This will run a set of diagnostics on your hardware to test all of it and determine what is functioning correctly and what is not.
If your RAM does not pass the tests, then you must replace the faulty ram. If your computer is still under warranty you should give Dell a call and have them do a service call on your computer. Telling them the results of the diagnostics test will very much speed up this process.
Best of luck!
please rate my solution
Jul 08, 2010 | Dell Inspiron 1525 Notebook
RAM QUESTION!!
Greetings my friend, regarding on your problem you will notice that if your computer/Laptop need to have additional RAM when your computer runs a program large enough to consume your RAM. You can add RAM anytime if you want to make your computer runs/loads program faster. RAM is used as a temporary storage of your running program or software so therefore if you have a large size of RAM then you can load large and lots of programs in your computer/Laptop with out experiencing log or slow in executing some of your request programs or applications. Also if your current RAM is not functioning well just like it is always restart your computer or dumping some programs and continues beep sound of your System Unit when you restart your Computer then that's the time you need to have a new RAM for your Computer/Laptop.
Jun 16, 2009 | Dell Inspiron 1521 Notebook
Reset Ram?
By default your RAM should reset every time you restart your computer and all of the memory should return to the system. If this is not the case I suggest defragmenting your ram.
If you are using windows Vista I suggest inserting your OS DVD into the drive, rebooting, and running the memory diagnostic tool.
If you are not running Vista you will have to download a program such as RAM Def 2.6 Xtreme to defragment the memory for you.
Jan 04, 2009 | HP Compaq Presario SR1420nx...
Acer Aspire Desktop RAM
I am not for sure why, but sometimes resetting the BIOS to the default setting will allow the computer to restart.
Dec 10, 2008 | Acer Aspire™ T180 PC Desktop
RAM chip is bad
Refer to your warranty for contact info, and if memory is covered. If so, tell them you had a professional diagnostic done, and see if they'll send you another memory chip. If not, then you will need to get the chip specs, and replace the chip yourself.
Jul 31, 2008 | Systemax Pursuit 4155 Notebook PC - Intel...
Dell latitude d60
WE NEED A ALL DRIVERS FOR DELL LATITUDE D600 MODEL LAPTOP - WINDOWS XP OS
Apr 26, 2008 | Dell Latitude D600 Notebook
Ram card
Pull the ram out again and reinstall making sure that it is seated firmly and both catches are closed. Other than you tearing wires out it seems like the likely suspect.
Dec 31, 2007 | HP Pavilion a800n (PP163AA) PC Desktop
Computers & Internet Logo
Alun Cox
