Question about Dewalt D51256K 16 gauge finish nailer kit
Hook it uyp to air and it blows air out the top not cracked or broken
    Sergeant:
  • 384 Answers
The gun needs to be rebuilt. Check on the internet for a rebuilding kit (diaphrams, valves, and O-rings) it will make the gun like new for about 15 to 20 dollars - take about 15 minutes to repair.
Posted on Jul 29, 2009
Vents blow out cold air instead of heat.
Check for a vaccumn line in the engine compartment that may have come loose or has a cracked rubber connector. The a/c system depends on vaccumn line to open and shut the dampers
Oct 06, 2012 | 2002 Saturn L-Series
My air conditioner blows air out on top by the window and on the floor but not in the middle on the dashboard. What part do i need to fix this and where is it located in the dashboard or under the hood?...
  • If the AC/heater air control doesn't work, you most likely have a vacuum line broken. All the air flow doors in the heater system are vacuum operated and without it the air will blow out of the windshield defrost vents. The common place for a vacuum line to break is under the hood where the lines pass near a hot area. The vacuum lines are normally a rigid black plastic tubing about 3/16 inch in diameter. They run across the engine compartment fastened to the section just below the wipers and air vent. The tube goes through the dash, usually near the steering column. When the tubing has been hot for long time it becomes brittle and cracks or breaks. Trace this tubing looking for a crack or break. The easiest repair is to cut out the broken section and replace it with rubber hose of the correct diameter. The hose needs to have an inside diameter that will fit snugly on to the vacuum tubing.
    Thanks for using FixYa.
    Gaker
Jul 26, 2011 | 1996 Buick Park Avenue
Can not get blower to blow all air through top vent, Wents to blow warm air at the bottom vent Get little A/C air through dash vents.
It's most likely a vacuum line, look under your hood (close to the cowl panel) for a disconnected, cracked or broken vacuum line.
In some rear cases, it could be the vacuum switch (in dash). Or vacuum diaphragm (under dash).
Hope this helps you ???
Jun 22, 2011 | 2000 Pontiac Grand Prix
Air does not blow out of top vents/atface level
Check for broken or cracked vacuum hose under hood....
May 26, 2011 | 2002 Chevrolet TrailBlazer
AIR CONDITIONING ONLY BLOWS THROUGH DEFROST VENT. CANNOT AJUST TO DASH OUTLETS. KNOB ON DASH IS FUCTIONING IS TURNING GISMO INSIDE AT DASH.
Its the Black vacumn pipe that will of cracked etc-look for the small thin black pipe that runs from left of engine bay and goes behind air box and top of engine-its a sod to replace but takes an hour or so!! Good luck..
Jul 19, 2010 | 1997 GMC Safari
Air blows out floor vents only. Blower is working and fan speed switch working
Air blows out floor vents only. My friend your Auto A/C system is control by Vaccum. Open up your hook and look for a black vaccum hose size 1/4" link into your fire wall. see if the hose is crack or broken. The other way to bypass the control: I can show you very detail by provide me the year I can get you the diagram for it. nguyen@ite.net
Jun 09, 2009 | 2001 Dodge Durango
Ac not blowing out top dash vents
The baffles that direct air, heated or cooled, are controlled by vacuum 'motors.'
You may have a vacuum line off somewhere or the vacuum reservoir is cracked or one of its connectors (thin plastic protrusions) is broken.
Aug 03, 2008 | 1996 GMC Sonoma
Air not blowing out top dash vents
Just posted my suspicions elsewhere:
Dewalt D51256K 16 gauge finish nailer kit Logo
230 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
