Question about Apex Digital AVL3076 30 in. HD-Ready LCD Television
The screen is white with a few horizontal lines. It can only turn off by unplugging or using the master switch. Thanks!
    President:
  • 563 Answers
G'Day!
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Jul 29, 2009
Black and White Horizontal Lines
Sounds like the graphics card just died. You will need that repaired.
Apr 15, 2014 | Apple iMac Computers & Internet
Tip
If Your screen shows a: white vertical line on a black screen or, a white...
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, carefully using your finger find the too hot transistor or, chip; or, use component coolant; spray the too hot component with a component cooler repower the TV, until the screen comes back to normal. To fix: apply white sylicone coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Garden
Tip
TV shows either: black screen with: white vertical or, horizontal line
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Just got this tv from friend. has no remote. screen is black. sound is good. when you push menu button, white line goes across horizontally the screen.
The horizontal line indicates the vertical deflection circuit is not working. Either the set is stuck in service mode for adjusting color (turns off vertical), or the deflection circuit has failed.
Some RCA TV sets have a "Service" switch in the back, down near the bottom of the set. Most of the newer sets use a combination of remote control and front panel buttons to get into service mode, and that can be turned off by unplugging the set and plugging it back in. Try looking for the mechanically operated service switch in the back first.
Jan 05, 2011 | RCA F25442 25" TV
White horizontal lines flicker and screen goes off.
check the wiring inside the monitor, pull the sceen out and move the wires with the screen on so you can see when it's working. then tape the wires where it works.
Dec 16, 2009 | Proview PL926WBi 19" LCD Monitor
WHITE horizontal lines across screen
You need to adjust Screen voltage (decease a bit) to disappear white lines on TV. If you want to do it yourself, let me know to help you further.
Regards,
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My tmobile dash lcd screen.
im trying it now i will post again if it works thanks
Jun 23, 2008 | HTC S620 Smartphone
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Apex Digital AVL3076 30 in. HD-Ready LCD Television Logo
99 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
