Question about Maytag SAV4655A Top Load Washer
WATER LEAKING FROM BOTTOM OF WASHER - Maytag SAV4655A Top Load Washer
  • pat gilmartin May 11, 2010
    require more info,eg,does water leak when m/c is filling up or during cycle or when m/c not in use?
    Scholar:
  • 51 Answers
Check the seal between the top plastic cap and the outer tub. There are 6-8 clips that secure the cap to the tub. My washer would leak water when full and start spinning. I found the seal split in two.
Thank you for contacting www.Fixya.com
Posted on Jul 29, 2009
Testimonial: "THANK YOU VERY MUCH. i will check it out."
I have water leaking from the middle bottom of washer, not leaking from hoses or water outlet
sounds like the water pump, pull the housing and look at the bottom center for a oval shape with two hoses.I bet you find the leak there.......GOOD LUCK
Nov 15, 2010 | Maytag SAV5710 Top Load Washer
Leaking water
Yes, Remove two screws rrom bottom of washer using puddy kinfe release the top panel bysliding in at crack between top panel and body the water pump is at the bottom left and may be leaking from hoses the other posiabilty is the selonid that controls the water inlet may be leaking
Aug 14, 2010 | Frigidaire FWSB5700DS Top Load Washer
Water leaking from the bottom of washer
I had this problem the other week we turned the machine around and took off the water hose got to the water pump and found 5cents, hair pins, badges ect in there once cleaned out and put back together worked great again and no more leaks!
Apr 26, 2010 | KitchenAid KAWS850L Top Load Washer
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
Jun 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
Maytag SAV4655A Top Load Washer Logo
235 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
