Washer wont agitate or spin motor hums i canturn
Washer wont agitate or spin motor hums i can turn the agitater by hand by using the belt
  • 82 Answers
If the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Posted on Jul 29, 2009
  • Scott Rod
    Scott Rod Oct 19, 2015
    I replaced the moter but this problem persists
Top load frigidaire washer will not spin, it agitates, it drains
You need to replace the starter cap on the motor this is why it will not turn and the smell is the cap that's not starting the motor it also will hum.
Dec 29, 2013 | Frigidaire FFLE2022MW Electric...
Will not drain, spin or agitate
make this test and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dog .
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente motor coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 25, 2013 | Washing Machines
Vbsr2080woww
follow this steps and fix it. God bless you
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dogs follow video.
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente of motor coupler
Transmission
Jul 09, 2013 | Washing Machines
Agitator not working wont wash water does drain
see this steps and fix it. GOd bless you
Agitator Dogs
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of motor coupler
Transmission
Will not agitate, motor runs ok and will spin dry ok.installed a slightly shorter drive belt on and it would agitate but not spin dry, I have a new bet kit ordered is there something else to check, th
see this causes and fix it. God bless you
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitaor dogs follow video.
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
Oct 02, 2012 | Maytag Washing Machines
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont agitate unless you move the agitator
defective motor,,,start whindin gone ,,,replace motor
Jan 17, 2009 | Maytag PAV2300 Top Load Washer
Kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
587 people viewed this question
Top Washing Machines Experts
