Computers & Internet Logo
B
Bob Comtois Posted on Oct 19, 2017
I messed up the setup for an internet connection. I don't know my password I put in . I'm able to get a strong Wi-Fi signal but can't connect . Is their a way I can fix this ??? Thank you, Bob
rainsocket
Level 1:
  • Contributor 32 Answers
  • Posted on Mar 12, 2018
rainsocket
Contributor
Level 1:
Answers
32
Questions
0
Helped
7070
Points
80
Yes0 every router has a litttle open hole in the rear. Open up a paper clip and push it into the hole and it will reset the router to factory defaults- such as admin and password (literallly), and then you can reset the password to your liking. Other choice is to connect an ethernet cable to the computer- that will bypass security and show you the current password
5 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jan 05, 2009
SOURCE: Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Anonymous
  • Posted on Feb 24, 2009
SOURCE: I cant get internet on my itouch although im connected to a wi-fi
My mp4 turns on and the screen turns blue and then it says loading.I cant get it to do anthing past now loading.How can i fix this,?i have tried everything.
Anonymous
  • 1865 Answers
  • Posted on Apr 15, 2009
SOURCE: Cannot Connect to Internet on Samsung NC10
Try running installation CD and then connecting
Anonymous
  • Posted on Sep 27, 2009
SOURCE: Trouble connecting ipod touch to password protected wi-fi
Settings->General->Reset->Reset Network Settings.i did this on my touch 3g & it started working!
Anonymous
  • 600 Answers
  • Posted on Dec 24, 2010
SOURCE: I bought 2 Acer Aspire one netbooks and I can't
you are seeing it strongly connected to the ROUTER---try unplugging the router for a few minutes and plug it back in----Does the netbook "SEE" the network? entered correct ssid? Is the wireless switch enabled on the netbook?
2helpful
2answers
I can't find the wifi settings on my harwa 32 inch home screen settings how do l connect
To connect your Harwa 32-inch TV to Wi-Fi, you'll need to follow these steps:
  1. Go to the settings menu: On your TV remote, press the "Menu" or "Settings" button to access the TV's settings menu.
  2. Find the network settings: Look for an option that says "Network," "Internet," or "Wi-Fi" and select it.
  3. Connect to Wi-Fi: From the network settings menu, select "Wi-Fi" and choose your Wi-Fi network from the list of available networks. You'll need to enter the Wi-Fi password to connect.
  4. Test the connection: Once you've connected to Wi-Fi, go back to the network settings and make sure the TV has a strong signal and is connected to the internet. You can also test the connection by trying to access online content, such as streaming video.
If you're having trouble connecting your Harwa TV to Wi-Fi, you may need to consult the TV manual or contact the manufacturer for further assistance.
Feb 12, 2023 • Cell Phones
tip
How can I go on Wi-Fi on my iPod Touch without a computer?
<p>Apple iPod touch Wi-Fi reception without using a computer. The device has a built-in 802.11 Wi-Fi receiver, which means that access to the Internet via a WiFi router that is in range. When connected to a WiFi signal on your iPod touch, you may be prompted for a password if you must know the password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not require a password. <br /> <p><br /> <p>1. Press the "Home" button of your iPod touch and move the cursor to the right on the device. Enter the unlock code if you have programmed. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen of the iPod touch Settings menu. <br /> <p><br /> <p>3. Play the "Wi-Fi" Network access to the names of all upcoming Wi-Fi to see. <br /> <p><br /> <p>4. Tap the name of a Wi-Fi to connect. If the network requires a password, you will be prompted to enter the password. <br /> <p><br /> <p>5. Touch "Join" to complete the connection. Now you can use any Internet-related programs on your iPod touch. <br />
on Aug 05, 2011 • Apple iPod touch
2answers
When I connect it to bt wifi, it says the signal is strong.
Connecting to a Wi-Fi network does not means you will get an Internet connection. That all depends how the Wi-Fi router is attached to the true network by Ethernet, DSL (phoneline), or cable modem.You must contact the network owner or administrator to confim why you cannot get an Internet connection even if the Wi-Fi connection is strong.
Irulu 7" tablet keeps disconnecting from internet. It's connect for a minute or so and then just drops. Just received replacements for 2 in the mail yesterday. No connection problems with old ones.
How many 'bars' are showing on wi-fi signal strength indicator (presuming you are using wi-fi for internet access)? If the signal strength is low, you could be losing connections that way, or there might be interference on the wi-fi channel that the tablet is using. Try changing channels in your wi-fi setup and see if there is an improvement in the behavior.
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
2answers
Can't access to internet connection...though it has wifi signal
Yup its have a wifi signal. But you need a wifi router .like mall they have a free wifi or a computer shop. If you want to open your wifi just 12 click menu-setting-connectivity-WLAN-on your wifi then search.then click the available wifi then if say connected.. You can now internet..
How do I setup my wi-fi on the new xbox 360? Do I have to have the internet adapter i believe, even if wi-fi is built into the system?
Go into your internet test glade, and search for locatons to connect to, if the adapter id plugged in you should be able to search for wireless signals. Connect to yours or the best connetion, but just know, WEP or WEP2 connections are password guarded.
2answers
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
3helpful
Need to protect my wireless network!
you must logon to the NetGear wireless router and setup wireless security. choose a security type usually WEP, type a key phrase or passphrase and voila, you will have to re-connect on your clients by entering the password when you get prompted for it.
 Grubhead
Grubhead
TUSHAR PANDYA
TUSHAR PANDYA
Level 1 Expert
Paul Bade
