Question about Sony KP-51HW40 51" Rear Projection Television
Tv will not turn on at all
When i press the power button from the tv or the remote,I get nothing.no light, no sound,nothing
  • 979 Answers
Good day sir/maam. chances are your tv's power supply section is in question. check for open fuse. Check also your mains voltage. if you have a multi-tester device, check the continuity resistance of the mains a.c. prongs of your TV. hope this helps, let me know your progress. thanks.
Posted on Jul 29, 2009
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Dec 27, 2014 | Magnavox Televison & Video
How to tune universal remote rm-300f+ to my tv
How to do an auto search for a Livewire Rm-300f+ Universal Tv Remote. These cheap (£1.00) remotes are available from poundland, etc.
1) Turn on your TV, ensure it it tuned to a channel and the sound is on.
2) Press the [set] button for about 5 seconds, until the LED stays on.
3) Press the MUTE button, the LED should flash twice.
4) Point towards the TV and press the power button. Don't worry if nothing happens.
5) Press and release the power button every second or so, eventually (for me about 120 times) the sound will go off. NOW press the [set] button to confirm your setting.
6) Pressing the power button again should switch the TV off. If not you're going to need to go through it all again.
Mar 18, 2010 | Sanyo AVM-3259S TV
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Jan 27, 2009 | Samsung Televison & Video
Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
Nov 11, 2008 | RCA 4-in-1 Universal Remote Control
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Changed bulb, now tv does nothing. . .please help
same problem. TV turns on but no picture or sound. when i press power button on the remote control orange light flashes for about a minute and goes back to red.
TV won't turn on. It iz frustating me a lot ay !
Mar 07, 2008 | Televison & Video
Silly remote
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Done.!
Jan 14, 2008 | Televison & Video
Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Oct 22, 2007 | RCA RCR412C Remote Control
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
