Question about Black & Decker Garden
My 24 volt 1200 watt cordless mower abruptly stopped while mowing and refuses to start again. The batteries show a full charge on my meter. can you give me an idea of what to look for. Thanks Cecil
    President:
  • 1,865 Answers
You'll need a DC voltmeter and have to start checking the circuit from the battery to the motor
Posted on Jul 29, 2009
Mower not starting.
The battery may have to be replaced.
Jun 05, 2016 | Garden
My m2560 woods mow n machine runs great but when it's cuting it drains battery I can't find the problem can someone help.
If your battery is draining then it has to be the alternator that is going bad. Unable to keep up under load.
Apr 07, 2016 | Woods Garden
My walker will mow for a short time but will stall if I dont turn off the blades
if it has an electric clutch to drive the blades, it is possible that the charge rate of the unit is insufficient to run the clutch and the ignition and so the battery gets to a point where the ignition suffers
have the windings of the clutch checked for resistance and failure
Apr 02, 2016 | Garden
Batteries shows fully charged. 24 volt shows 27 volts fully charged but shows RED light when install in mower.
it's never the motor, it's always the batteries.
you are most likely testing the batteries with just a meter and not under load
you will need a tool to put the battery under a load, it will end up costing more than two new batteries.
just replace the pair and you will be fine, i have done enough of these over the last few years.
good luck and you will have no problems with the new batteries.
May 21, 2015 | Electric Earthwise Corded Lawn Mower...
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
Battery won't stay chaRGED NO AMPS SHOWING ON AMMETER.CAN BE STARTED BY JUMP AND WILL RUN BUT STOP AND WILL NOT START AGAIN WHATS MY PROBLEM?
it could be a fuw things doing this,,,
check that the engine is charging the battery up when its running,,use a volt meeter across the battery it should show 13.5 volts if its charging up ok,,,,
then check that the voltage regulator is not draining the battery when the engine is not running,,,
fully recharge the battery first then check that it holds this charge,, take off the battery lead and leave the mower for a week or so if the battery has gone flat then you need a new battery!! winter time kills off batterys if there not kept on trickel charge,,,
there's a tip,,,,buy a solar charger,,,and hook it to the battery when your not using the mower,,it will keep the battery toped up for free???
Jun 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Sep 23, 2009 | Garden
Batter life in the second season
When batteries are only used seasonally, and they are stored, they can become damaged from weather or from storing them when they are not fully charged. In general, batteries used seasonally will have a shorter lifespan, so it sounds like you likely need a new battery. Check out http://www.batteryinternational.com/electric-lawn-maintenance-batteries.html for a replacement, and be sure to charge it fully before storing.
May 19, 2009 | Remington PowerMower 17-Inch 60-Volt...
Garden Logo
724 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
