Televison & Video Logo
Max Sessions Posted on Oct 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony XBR-70X850B won't power on and has no standby light. I've replaced the power supply with no change. Need help to positively identify failing component
Larry
Level 3:
  • Sony Master 5,042 Answers
  • Posted on Oct 19, 2017
Larry
Sony Master
Level 3:
Answers
5042
Questions
Helped
1239453
Points
18413
Have you checked your power supply voltages to see if they are correct both with the set off and on?
5 Related Answers
Anonymous
  • 9 Answers
  • Posted on May 12, 2008
SOURCE: RE: Flashing "Standby" light
Go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 for a step-by-step solution with pictures. $21.83 is all it cost me. I fixed my own TV as many others on that forum have. Feel free to contact me at [email protected] if you run into difficulties.
-Dave
Anonymous
  • Posted on Oct 20, 2008
SOURCE: sony xbr standby light problem power wont turn on?
the problem either in short horizontal output x-sistor or in power supply unit.
Anonymous
  • 201 Answers
  • Posted on Apr 29, 2009
SOURCE: standby light blinks 13 times
13 blinks is backlight error.. can be 1 of 2 things, 1st bad inverter board (on left side panel looking from back) it has several plug ins to the panel as it supplies voltage to the backlights.2nd could be panel itself as backlights are built into it they can't be replaced. Inverter is probably around $200 +labor, panel= buy new tv... they are outrageously expensive. Good luck!
Anonymous
  • 534 Answers
  • Posted on Jun 05, 2009
SOURCE: Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu '[email protected]'
Anonymous
  • 178 Answers
  • Posted on May 23, 2010
SOURCE: My Sony KDL-26S3000 won't turn on it well get stuck in standby
Please see the troubleshooting chart, BU1 board part # A-1268-869-A, cost approx $230.7685cfa.jpg
How do a get the TV to stay on?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Sony XBR-70X850B turns on, displays picture, then shuts off, and flashes LED lights 4 times.
HI
in this case most common problem is ld board or panel if the set red light blink 4 times
1helpful
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
9helpful
2answers
Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
2002 36" Sony Trinitron XBR High Def TV. When you
Your power supply board is dead, do you know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem..
I was watching a dvd on my week-old Sony Bravia XBR-52HX909 for the past three hours when the screen suddenly went blank. The standby indicator light in red started blinking. I attempted to turn on the...
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
3helpful
Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
1helpful
We have a Sony Trinitron XBR tv, S# 9000572, made in 7-02 now when we power up a red stand by light comes on and that's it..we did not get a manual with the purchase from Circuit City...any ideas?
Some of this series of Sony units had a switching regulator integrated circuit that commonly failed. As I recall the standby was still ok, but no main power supply. There are many other possibilities of course such as an open main power supply fuse. This could happen just due to wear and tear, or as the result of a short such as in the horizontal deflection circuit. If you are etchnically inclined you may want to check out the power supply reg. i.c. I mentioned. If the set uses one it is a flat pack type & mounted to a heat sink on the power supply board. The number on the part itself should be ok to get a generic replacement at someplace like mcmelectronics.com.
Sony xbr standby light problem power wont turn on?
SONY XBR 60" STANDBY
Check the door for the lamp...over time mine distorted from the heat, and this was an error code for the door now being closed. Temporarilty I wegeded something in there to hold the switch closed, but ended up replacing the door.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
