Question about Dryers
Dryer is shrinking clothes on low heat
My wife claims our dryer is shrinking the clothes on low heat. What might be causing it?
    Scholar:
  • 76 Answers
Is this a traditional kenmore dryer. Check your temperature selection switch in your counsel. It should have a small resistor on it. It should read about 10 ohms. if not than change the switch. That resistor is used when you set your selector on low heat. if it checks oout ok, the i would check your thermostat on the bottom panel. Like i said if this is a traditional kenmore dryer. You didnt really give a model number or brand of dryer. but if its a kenmore, try checking it out with a multi meter.
Posted on Jul 29, 2009
Dryer suddenly shrinking clothes
The machine has two issues that could cause this:
1. As heating elements age, they got hotter before they burn out.
2. There is a thermostat on the heater element enclosure that controls the heat, this might be going bad.
If you open the panel to see the heating element, there should be a tech sheet in the machine that has temps listed for different settings.
While you are in there, you need to clean it out. It probably has a lot of lint in the machine and this can cause a fire hazard.
The way that you test it is to put a load of damp clothes in the machine and set it and then take the temp at the outlet. You need to use a meat thermometer to check the output temp. Use the chart on the tech sheet to tell if the thermostat is working right. Also it goes without saying that you should unplug the machine for most of this.
Feb 17, 2014 | GE Dryers
Shrink clothes
high heat can sometimes cause clothes to shrink
Jan 27, 2014 | Zanussi Washing Machines
Wrinkled clothes
My wife, who runs "dryer central", stops the dryer short of complete drying and hangs the clothes that are easily wrinkled.
You may also have the heat set too high, or the time set too long, causing the problem.
Try experimenting.
Be blessed.
Nov 05, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer TOO hot
What is the model number of the unit?
Nov 10, 2012 | Dryers
Hi the problem of my maxx 7 dryer is that when i wash clothes they get smaller (all of the clothes not specific one) how can i solve this problem if its not solved i will sell it so plz help.
I think that you would have the same issue with any dryer. Try LESS heat, as you seem to be shrinking the items. Shrinking is typical on new clothes, but should stabilize after a washing or two.
Dec 07, 2010 | Dryers
Dryer is too hot even on medium.
Could be a thermostat not working, this would cause exessive heat. If any repair has been carried out on thermostats maybe wrong one has been fitted, but 1st answer is most likely
Feb 12, 2010 | Amana NDE2330AY Electric Dryer
Tumble dryer overheating!
It could be a faulty thermostat, or the high/low heat switch is faulty, it will be one or the other.
Hope this helps.
Jan 17, 2010 | Dryers
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
My nepture dryer wringles the clothes very badly
Most common problems with wrinkles is too much clothing is in the dryer causing and allowing to tumble freely. 2nd, the dryer is not putting out enough heat and cause the clothes to stay damp and stay winkles. 3rd the exhaust fan may be not working properly. you might able to solve the problems by trying to reduce the amount of load, allow it to tumble freely and I don't know if your dryer are putting out enough heat. the cause of low heat can be the heating element is going out. hope that help some.
Aug 09, 2009 | Maytag Dryers
Dryers Logo
268 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
