Back to:
Tags:
HP PSC 1315 All-In-One InkJet Printer
Need to reinstall hp psc 1310 series all-in=one... (by 39 users)
posted by she2girls on Nov 23, 2007
sometimes it would print and then sometimes it would not .Now I need to re-install it to my computer. I unisalled it so that I could re-insatt it,now I am kind of lost what I should do next
i can't install it my hp psc 1315 printer all-in-one.i've tried my cd but it doesn't help
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
38 Other Users Have The Same Problem
Comment by Guest, posted on Nov 15, 2008
I have HP PSC 1310 series But HP Director on click scan document or scan picture not working. Please suggest me how is work as my Cd software has been currupted.
Comment by RYCabc123, posted on Nov 11, 2008
my daughter lost the disc to install the printer and I want to keep this printer, how can I install my hp psc 1310 Series all-in-one printer?
Comment by mhoy125, posted on Oct 30, 2008
hp psc 1310 series
hi officejet 4200 series
Comment by samisadaqah, posted on Oct 24, 2008
Comment by Blake_schape, posted on Sep 17, 2008
need to reinstall printer b/c don't have installation disc
Best Solution
posted on Nov 19, 2008
FixYa! (100)
bassettmaria
Rank:Apprentice Apprentice
Rating: 95%, 3 votes
hi i need to re-install my hp psc 1310 series but i have lost my cd
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on need to reinstall hp psc 1310 series all-in=one printer/scanner/copier:
I don't want to Accept this solution
Solution #2
posted on Nov 30, 2007
FixYa! (100)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1561 votes
Thank You!
Solution #3
posted on Oct 19, 2008
Helpful (85)
scrapy1992
Rating: 85%, 3 votes
i need to re install my HP PSC 1315 series printer and i lost my CD-ROM
Thank You!
Solution #4
Not Rated (0)
aljonoon
Rating: 0%, 0 votes
i want a free download installation to install my hp scaner so that i can use it effectively.
Thank You!
Solution #5
posted on Jun 20, 2008
Not Rated (0)
Guest
Rating: 0%, 0 votes
if your HP printer software keeps reinstalling itself, then just open services.msc, and Stop and disable HP CUE Device Discovery Service. the problem shouldnt reoccur.
Thank You!
Solution #6
posted on Dec 07, 2007
Not Rated (0)
boazworld
Rank:Master Master
Rating: 78%, 9 votes
base on the information given.
you have re- installed it but it does not work.
If it is Usb connection chech that all usb Drivers are installed correctly in your computer.
because once you plug it in it should recognise that there's a new hardware that needs to be installed.
to check that you need to
right click on my computer, hardware or device manager and look for any yellow sign on the universal serial bus controllers.
re-install drivers for that.
Then go to the hp website.
HP.com download the driver for hp psc 1315 all in one.
That should work.
If you have done all that and it doesn t work.
hit me up.
Thank You!
Can you Help with these Printers problems?
I replace the USB device, and take apart the carring...
hot to clean the inside part of the glass. Every time I...
prints for a while and then stops working ,won't print out...
I have changed cartridges and this does not work. However,...
I cannot eject the memory card by pushing in. Is there...
38 Other Users Have The Same Problem - Continued
Comment by sid6230, posted on Aug 31, 2008
the cd installer is misplaced..even if i have it, my cd-rom does not work. i want to install it instantly.
Comment by suejoshi, posted on Aug 28, 2008
I unisalled it so that I could re-insatt it, But when I put The CD in computor half way the computor says there is error in installing it., and the program might not work now I am kind of lost what I should do next
Comment by seemagro, posted on Aug 13, 2008
My CD showes that it is compatable with Windows 98,ME,2000, & XP only. Can it be upgraded to work with VISTA.
I am about to throw the 3-in-1 in a compactor and make one LUMP OF SOME IT.Can someone out there help.
Comment by Guest, posted on Aug 12, 2008
When I installed my software for my digital camera, my Hp director disappeared. I uninstalled my printer and reinstalled, then the scanner wouldn't work. I had to reset my internet services last night and now my printer won't print so I uninstalled it again and now it won't reinstall at all. My disc will not bring up the wizard and It will not install at all
Comment by tajelsir2004, posted on Aug 03, 2008
I have lost CD for installatlion of printer ,so I need to reinstaa hp psc 1315all-in-One inkJet Printer
Comment by Guest, posted on Aug 02, 2008
my hpsc 1310 series is not working i made an mistake an unstall it now it wont reinstall
Comment by Guest, posted on Jul 26, 2008
can not find download lost disc
Comment by moneim1997, posted on Jul 19, 2008
I HAVE LOST THE CD FOR MY PRINTER PSC 1310
Comment by Guest, posted on Jul 16, 2008
I am unable to print using my 1315 printer . The original software has been lost.
Comment by brookpop, posted on Jun 19, 2008
I need to install my printer on my laptop and can't find my CD to download Can I download off the internet?
Comment by k-trouble, posted on Jun 18, 2008
I upgraded my computer to a newer version of Windows XP Home edition and everything rebooted it's self and we had to install everything again but the printer( HP PSC 1315 All-in-one) won't get installed I've tried using the CD but when it does work it said that the printer is not connected to the computer and it is!!!
What should I do?
Comment by supaflysandy, posted on Jun 16, 2008
i had lost the CD for re-installing the pinter.
Comment by Guest, posted on Jun 16, 2008
i had lost my CD to re-install the pinter.
Comment by Guest, posted on Jun 03, 2008
scanner is not working
Comment by phillipsa2, posted on Jun 01, 2008
I need to reinstall my HP PSC 1315 All-In One inkJet Printer, I have the CD but it is not working. Is there a way to do it from on line?
Comment by Guest, posted on May 28, 2008
Lost setup disk and TrayApp appears.
Comment by Guest, posted on May 04, 2008
i uninstalled it and tryed to re install it but my disk wont work
Comment by athatha, posted on Apr 14, 2008
i have the same problem, i got my whole computer restored and now i need to rerinstall my printer, but the cd doesn't work!!!
Comment by Guest, posted on Apr 11, 2008
help me!!!!!!!!!!!!!!!!!
Comment by Guest, posted on Mar 24, 2008
cant find my1310 cd for my all in one printer,scanner,and copyer
Comment by Love818, posted on Mar 01, 2008
I am having the same issue with my hp printer. If I restart my computer then everything that it has been prompted to print begins to print. My scanner also will not work since the printer has been re-installed. Can I get some assistance with this.
Comment by Guest, posted on Feb 19, 2008
I reinstalled my printer and it prints most of the time, not all. But my major problem is that I can't get the scanner to work.
Comment by Guest, posted on Feb 18, 2008
cd broke
lost my disk for hp psc 1315 how can i get it reinstalled?
Comment by Guest, posted on Feb 07, 2008
  • well not print
Comment by kaygeex, posted on Feb 06, 2008
I have uninstalled my psc 1315 and now when I try to re-install using the CD, nothing happens.
Attached is the log from Process Monitor.
Any suggestions?
20080206231424:0E49FBE82B:0001(Setup.exe)Parsed command line: "F:\Setup.exe"
20080206231424:0E49FE6BA7:0001(Setup.exe)Using datfile: F:\autorun.inf
20080206231424:0E4A0267A9:0008(Setup.exe)## GetValueByLang( f->c_str(), _T(Version), _T(LanguagesInthisCD) failed
20080206231425:0E4A04ECEC:0008(Setup.exe)## Found ENU already installed on this machine! It is not on our CD though, so we are continuing
20080206231425:0E4A0712E9:0008(Setup.exe)## GetValueByLang( f->c_str(), _T(Version), _T(LanguagesInthisCD) failed
20080206231425:0E4A07F96B:0001(Setup.exe)System LangID = 7177. mapped to ENU
20080206231425:0E4A08DE8D:0008(Setup.exe)## The system language is ENU, but it isn't on our CD!
20080206231425:0E4A0A5174:0008(Setup.exe)## We couldn't figure out a language to use, and are returning FALSE from CICECmdLine::GetLanguage()!
20080206231425:0E4A0CCE44:0008(Setup.exe)## GetValueByLang( f->c_str(), _T(Version), _T(LanguagesInthisCD) failed
20080206231425:0E4A0FB35D:0001(Setup.exe)Parsed command line: "F:\Setup.exe"
20080206231425:0E4A111391:0008(Setup.exe)## GetValueByLang( f->c_str(), _T(Version), _T(LanguagesInthisCD) failed
20080206231425:0E4A12B6F7:0008(Setup.exe)## GetValueByLang( f->c_str(), _T(Version), _T(LanguagesInthisCD) failed
20080206231425:0E4A183625:0008(Setup.exe)## Either manufacturer or _productSeries is empty.
20080206231425:0E4A1AC375:0001(Setup.exe)Parsed command line: "F:\Setup.exe"
20080206231425:0E4A1C748B:0008(Setup.exe)## GetValueByLang( f->c_str(), _T(Version), _T(LanguagesInthisCD) failed
20080206231425:0E4A1D97F0:0008(Setup.exe)## GetValueByLang( f->c_str(), _T(Version), _T(LanguagesInthisCD) failed
20080206231425:0E4A20A9B6:0001(Setup.exe)Setup returning 1603
Comment by Guest, posted on Feb 06, 2008
i need help in reinstalling my hp psc 1315 all-in-one printer scanner copier?
Comment by bojoe, posted on Jan 05, 2008
i accidentally restarted my computer and it uninstalled my printer. i can't find the disk and i need to reinstall it.
Comment by Guest, posted on Jan 02, 2008
i lost my cd to my printer hp psc 1315 all in one printer i hade the link but when i my computer upgrade i lost the link or cant find the link no more
Comment by Guest, posted on Dec 07, 2007
Comment by Guest, posted on Dec 05, 2007
I am not able to re-install my HP PSC 1315 all in one printer after having to un-install it. I've used the CD but it does not work. Any solutions availabe?
Comment by matsCo, posted on Nov 27, 2007
Even
Comment by LynnieNo1, posted on Nov 24, 2007
totally paper gets jammed all the time.  and now the scanner works super slowwwww
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
