Dishwashers Logo
A
Anonymous Posted on Oct 18, 2017
How to fix dishwasher that doesn't drain - Dishwashers
Doesn't fully drain after cycle completed. How do I fix it?
most likely you have a lot of debris in the pump housing. you can remove the lower arm and then the cover from the top of the pump. clean out all the debris. and try again. if it does not drain replace the drain pump.
2answers
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
My whirlpool quiet wash plus diswasher is not draining water. How do I fix it?
Hi
Daniel
Aug 14, 2011 • Dishwashers
My dishwasher doesn`t drain. there is water at the bottom at te end of every wash... what`s wrong? how can i fix it?
Hi
Daniel
Water doesn't drain
Hi
Daniel
My dishwasher does'nt drain, how can I fix that?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
2answers
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 • Dishwashers
Top Dishwashers Experts
Mike Cairns
Mike Cairns
