Question about Archos 605 WiFi Digital Media Player
My archos 605 wifi is stuck in recovery
My archos 605 wifi is stuck on the recovery screen(code 104) and I can only see it in Device Manager but not in My Computer. I've restarted it several times but nothing. I've also pressed on Repair Disk and Format Disk but still nothing.
  • 4 more comments
  • wonder_bro Jul 29, 2009
    when i plug in the usb it does nothing it doesnt appear anywhere in my computer and whenever I turn it on it returns to that recovery mode screen.
    cannot see the archos in my computer
  • tech119 May 11, 2010
    are you able to enter usb mode, if so copy the contents of your device to your computer and email me tech @ Lawckedgaming.com if you cant, find a friend with an 2.5" IDE usb enclosure so you can copy the files.
    are you able to access the drive contents via computer&usb?
    were you able to enter usb mode and look at your directory on the drive?
I fixed my son's 605 4 GB had Recovery code (104) on it These are the steps i followed
* Use the computer for this process that you always used for this archos
* Download the firware Upgrade 2.1
* Plug the Archos to Pc
* When the white screen comes up do format
* Wait until all done then put the firmware in to the root sector of the Archos
* Safely remove the usb for Archos from your pc first and then unplug the cable.
* Do not pick any option on the Archos screen
* Just turn it off from the power button by holding it until it turns off
* Wait about 5 minutes and plug in back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving wait until it is all done and it will shut off. Turn it back on Your archos will be back to normal.
When you go to download from Archos site it will explain how to download depending upon how your device pops up on your Pc.
Hope this helps
Posted on Aug 17, 2009
Recovery code 104 comes up
your answers are here:
http://www.fixya.com/support/t345835-archos_605_recovery_code_108
Jul 19, 2009 | Archos 605 WiFi Digital Media Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Archos 605 wife (wife firmware)
If you chose any of these options already your Os is gone..
try this solution
I fixed my son's 605 4 GB had Recovery code (104) on it. This might work for other error codes too. These are the steps i followed
* Use the computer for this process that you always used for this archos Archos should be plugged in to Pc before starting the process.
* When the white option screen comes up pick the format disk
* Wait until all done do not pick any option on archos after format is done Pc should recognize your archos in 5 seconds
* Put the firmware in root section of the archos not in any folder.
* Wait about 5 minutes and plug it back to pc
* it will come up with white screen again but this time it will start Update you will see the progress bar moving, wait until it is all done, it will shut off. Turn it back on and  your archos will be back to normal
Mar 20, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 has got recovery code 102 and i cant get it to conect to my pc to fix it can u halp
* Use the computer for this process that you always used for this archos Archos should be plugged in toPc before starting the process.
Mar 19, 2009 | Archos 605 WiFi Digital Media Player
After formatting the archos5 ,the device doesnt get recognised
* When the white option screen comes up, just pick the format disk
Mar 16, 2009 | Archos 605 WiFi Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
It shows-recovery error-102 & error-104
Hi
i had same issue. nothing worked until i saw a guy who fixed his by dropping it on floor?
i dropped my archos in the protective case from 2 feet off floor. the bloody thing when came back to life, 100% good. i think the hard drive was stuck and the fall fixed it!! it cannot hurt as yours is broken still i guess. hope it works for you to
Jan 07, 2009 | Archos 605 WiFi Digital Media Player
ARCHOS 605 WIFI FIRMWARE DISABLED
hitesh_rao - the reset button is at the bottom by the USB and docking ports. Tiny hole, need a pin or paper clip. Once pressed, just switch it back on.
This may be a stupid question, but when trying to configure the TV IR controller function and entering the relevant codes for my TV's, it asks 'did the TV switch off = Yes/No?'
None of my TV's switch off and then I cannot go any further with the config. Is this right? I have logged this with Archos FOUR times now, and they just respond with 'the controller does not control your TV'. I am fully aware that it is not a TV controller, but then why does it want to switch off my TV during the config? I just want them to answer that question.
Somebody please help!
May 22, 2008 | Archos 605 WiFi Digital Media Player
PC no longer recognizes my Archos 605
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
Mar 24, 2008 | Archos 605 WiFi Digital Media Player
Recovery code 104
Same issue on my Archos 605 wifi 4GB
The Repair didn't work so here's what I did.
1) connected via USB and got all my Picture, Videos and Music to a safe place.
2) Downloaded firmware update.
fouund it here - http://www.downloadplex.com/Drivers/Firmware/Archos/Download-Archos-605-Wifi-4GB-Firmware-2.1.04_109044.html
3. Copied update to root of archos drive and rebooted
4. Archoes installed the update and rebooted and came up to desktop again
5. reinstalled plugins (thank god I saved them) copied plug-in to root.
6. Back on the road again
Feb 23, 2008 | Archos 605 WiFi Digital Media Player
Archos 605 WiFi Digital Media Player Logo
866 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
Jim Goldsmith
Jim Goldsmith
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
