Question about Garden
Attach ground wire
How do I attach ground wire that is not connected when I bought this re-condidtioned blower
  • 44 Answers
Assuming its an electric blower----- plastic blowers normally do not require an earth wire, check your plug to see how many wires in it,if it has only 2 wires in it[live and neutral] then the blower has no earth wire.if you dont feel safe in using blower add a safety trip switch to the socket and then plug in to the safety switch.this protects you.. you can buy the t/s in any good electrical store.
Posted on Jul 29, 2009
1973 dodge dart blower motor wiring
I would just attach it to the nearest good grounding point
Nov 21, 2011 | Cars & Trucks
I would like to test my heater blower motor how do i go about doing it?
Hello: With jumper wires from the battery attach the positive wire to the positive connection on the blower motor and the negative wire to the ground (black wire) connection on the blower motor. You may have to remove the blower motor to do this. Check your blower motor connections for burned or melted wires.
Jan 06, 2011 | Pontiac Grand Prix Cars & Trucks
The new blower motor I just bought for my 1995 Cutlass Ciera only has one spot to connect one wire! My old blower motor has two wires coming out of it??? Will this new one work and how??
The lead (single) is the hot lead. Your original had two, the other is the ground and attaches to one of the mounting screws. Alot of aftermarket cos do this
Jan 02, 2011 | Oldsmobile Cutlass Ciera Cars & Trucks
Forward blower not working
unplug the the 2 wire plug on the blower and attach a wire from the post on the blower that the black wire went to the the body (ground it) attach another wire to the other post on the blower and touch to hot post of battery if the blower comes on check your relay or switch.NOTE BE SURE THE TWO WIRES YOU CONNECT TO THE POSTS IN THE BLOWER DO NOT TOUCH EACH OTHER!
Jul 29, 2010 | 1999 Ford Econoline
2003 Suburban heater fan will not working.
three things left to check,
using test light see if you have power at motor with key and switch on,if you do replace motor,if not locate blower motor resistor it will be close to motor,check for power going in,last is the heater control assembly
Dec 10, 2009 | 2003 Chevrolet Suburban 1500
Saturn 2001 LW-300 Saturn blower motor will sometimes work and sometimes not work. Do you think it is blower or resistor or switch
Most of the time this has to deal with a poor ground connection. Everything around the motor is plastic so the ground wire is the only place the motor ground. I gave up trying to find the problem connection and attached a secondary ground to the motor and fixed it. U get to the motor under the hood in between wipers. Remove filter -remove 4 screws on blower cover. The blower slides out. attach a ground wire on the rear screw on the motor. Find a good ground for that wire & your done. I put a small hole under the blower and attached it to the frame ground right behind radio. Any good ground will work.
Oct 16, 2009 | 2001 Saturn L-Series
Connection
the green wire will attach to the dryer cabinet. The white wire will attach to the middle and the other two(red& black) will attach to the outside of the terminal block.
Good Luck!!
Feb 23, 2009 | Dryers
Heater not blowing
Blower motor ground is generally to the body. Just attach a decent gauge wire (I use 12gaq or 14ga) to the body and using a loop end (crimp connector), remove one fastener from the blower housing, put screw through wire end and re-fasten. This will re-establish ground. Grounding is likely the least looked at part of the electrical system, but is extremely important for all electronics to operate properly. On every vehicle I own, I go further than I outlined, running a 10ga wire from the battery, attaching it to the near point on the fender, around to the firewall, through the firewall to the dash bracket inside the cabin and another branch to the opposite fender and radiator support. I also add a second ground to the battery, directly to the block in a different place than the standard ground, usually to one of the starter mount bolts. In doing this, I eliminate any possibility of ground loss to essential components.Your original ground wire should be black and likely was attached by a spade connector much as I outlined above.
Feb 05, 2009 | 1999 Jeep Grand Cherokee
Change 3 prong dryer cord to 4 prong
well the green wire is the earth ground,you could connect it to a pip,or to the outlet box.
May 10, 2008 | Dryers
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
