Question about Nintendo Wii Console
Wii will not even power after it has fallen of the stand
The wii fell and now it will not even turn on. I have a tool that shows power is getting to the cord and the on button but it will not turn on. Any suggestions. Thank you
SOURCE: Wii wont take in CD!
maybe you could get a random disc and try to shove it in. if it goes in and the wii tries to read it then you can probably do it with the real games. but youll need to work out how to pull the first cd out before that...
Posted on Sep 20, 2007
SOURCE: Disc stuckin wii
look there's no easy way to get that out I had that happen to me on a ps2 and I removed the cover and got it out,but that voids the warranty .There's no way of doing it with out removing the cover so either take it back or remove the rubber grommets and get out a phillips head screw driver or what ever it uses
Posted on Oct 06, 2007
  • 9 Answers
SOURCE: wii eject button will not work
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Posted on Jun 07, 2008
SOURCE: Power Outage & Now Wii Won't Power Up...
Just and addendum to sakkyoku's post "Solution #1"--
I had the exact same problem:
-Brief power outage
-All devices plugged into same outlet functioning properly
-No red standby light on the Wii Console
Instead of just unplugging the power source to the Wii, I had to unplug EVERYTHING (SD cards, sensor bar, A/V cable) from the Wii and let it set for several minutes.
When you plug it back in, ONLY plug in the power source and hopefully (as it did in my case) your Wii console will shine a beautiful red light of relief.
Posted on Dec 15, 2008
  • 4 Answers
SOURCE: Nintendo Wii AV Cables not work
The AV cable that came with the Nintendo Wii is not designed for high-definition TV (HDTV) or enhanced-definition TV (EDTV) to view 480p progressive output. If you are connecting to a 480p TV, you will need a Wii Component Video Cables (maybe like the Gamestop cable you have).
Posted on Jul 27, 2009
Hello. i just got a wii like not even a year ago. well it didnt actually fall off of anything it just fell over on its side. and now when you turn it on it doesnt show picture or sound. but the green light...
It sounds like your video card on the Wii has malfunctioned
I would email http://www.nintendo.com/consumer/webform.jsp nintendo directly especially if the wii is less than a year old. They will either repair it or replace it for a new Wii.
However I would not say it fell on its side as they may not replace it :)
Apr 04, 2011 | Nintendo Wii Console
My wii after trying to run homebrew channel doesnt have power
You probably just need to reset your Wii's power cable. This happened to a lot of people I know.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#no_power
Aug 14, 2009 | Nintendo Wii Console
Power outage this am. Wii won't even turn on
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Aug 09, 2009 | Nintendo Wii Console
My wii just won't turn on!
my wii dont want to turn on it dont do nothing
Aug 06, 2009 | Nintendo Wii Console
Wii game will not eject from wii
Unplug your console wait 30 to 60 seconds plug it back in. See if it will eject then. NOTE*** NEVER INSERT A KNIFE IN TO YOUR CONSOLE
Jan 24, 2009 | Nintendo Wii Console
Broken Wii?
so it fell from the shelf huh! try to replace your A/V cable with a new one.maybe it was pulled of when the wii fells causing the wire inside to get cut.hope this one helps!
Dec 21, 2008 | Nintendo Wii Console
Wii remote will not work
Ok, glad it now works for you. Please rate this as fixed so it does not show up in the unsolved problems list.
Many thanks,
Mowcius
Aug 02, 2008 | Nintendo Wii Console
My wii doesnt play the game discs anymore
try disconnecting the power source and wait 2 minutes then plug back in it should be ok
Mar 17, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
20 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
