Question about Kenmore 659 Electric Dryer
We have a Kenmore dryer series 90 model #11066904690 that we started spelling a burny smell. We took off front panel and vacumed out we tryed to use it again and same thing happed and then shut off completely. Any suggestions?
  • Cool Blue Services
    Cool Blue Services May 11, 2010
    Can you clarify the smell for me? Example: Burning cotton, nylon, rubber, plastic, paper, etc. If it shut off completly, I would suspect a contaminant combusted in the heating chamber causing the overheat switch or high heat thermal fuse to open circuit the system to avoid severe damage, fire, etc.
  • 401 Answers
This could be a couple of things. But more than likely the motor has burned out. It could be a wire has burned off, or even the timer has burned. Since you say it "shut off completely", I would have the power cord checked where it connects inside the dryer. UNPLUG it from the wall first! I have seen one wire burn off there from being a loose connection. There is a cover plate you can take off and look inside.
Posted on Jan 02, 2010
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
I push the start button on my Kenmore 90 Series, and it tries to start but it does not. Do it a couple of times and you smell burning.
sounds like the motor but here is a website that will help you, Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 24, 2010 | Kenmore Dryers
Kenmore 90 Series, 10 years old; Dryer was making funny noise and stopped in the middle of a cycle. There was a burnt smell when it stopped. Cannot turn drum manually either. What are possibilities?
OF COURSE SOMETHING BURNT INSIDE THE SYSTEM. YOUR MOTOR MIGHT BE BURNT. 90 SERIES, YOU MUST HAVE THE LINT FILTER ON TOP CORRECT? TAKE FILTER OUT, UNSCREWS THE TWO SCREWS, PULL TOP PANEL TOWARDS YOU AND LIFT UP. DISCONNECT LID SWITCH CONNECTOR, UNSCREW TWO SCREWS HOLDING FRONT PANEL ON, REMOVE FRONT PANEL, TAKE DRUM OUT AND CHECK THE UNIT. GOOD LUCK
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore Dryers
I need to get to the thermal fuse in my Kenmore 90 Series electric dryer model # 110.66902690. I took off the bottom front panel and can't find it...I'm really not even sure what it is I'm supposed to be...
ok the heater is on the right side of the unit standing from the front the thermal fuse is located behind the thermastat should be round black objects that have to wires going to them it is recommend that if you have a bad thermal fuse you replace your thermostat wich is the bigger round plastic also might want to check your vent out of the house for a restiction
Jun 02, 2010 | Dryers
Kenmore Series 90 drive belt
Access to the belt may be from the front.
Feb 25, 2018 | Dryers
My Kenmore Series 90 dryer won't run as it appears the door does not hit the actuator. It would appear either the door has moved to a lower position or the actuator has moved up into the dryer. May I ask...
The door switch or actuator is broken. A common problem. On most Kenmore dryers this is replace by lifting the top. Since you haven't given the whole model number I will discuss raising the top on the most common model.
If your model has a lint filter at the top the slide show below should show you how to raise the top.
Kenmore Dryer
Disconnect power to unit. Lift the cover from the lint filter or if yours is the one with a filter and cover together, remove the whole filter. You will see 2 screws under the cover/filter, remove them. Now, you will need a putty knife or a thin shafted straight screw driver to remove the top panel. Push the putty knife or screw driver to "pop" the front top clips. The top panel will hinge back towards the wall and can be left there. Just inside the top of the front panel, you will see 2 screws, remove them. You will see the wires for the door switch on the right side. *** the top of the front panel toward you to gain access to the switch for replacement.
Reverse process for reassembly. Good Luck
Sep 19, 2009 | Kenmore Dryers
Kenmore 70 series top loader washer machine smells like its burni
you had the clutch coupling replaced sometimes i have noticed that the smell will last a few loads but no more than that
Apr 22, 2009 | Washing Machines
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 659 Electric Dryer Logo
235 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
