Question about Goodman CKL42AR42 Air Conditioner
Goodman Air (outside unit)
The unit was running fine and cooling the house well. We bumped into it moving furniture and slightly moved the outside unit and now the Air wont come on. The thermostat says it is on but nothing is happening outside. Replaced the fuses on outside wall but dont see a circuit breaker outside. Reset all breakers inside as a checking measure.
I dont see a reset button anywhere. Thoughts?
Thanks..
Sandy
  • Shopnspend Jul 29, 2009
    No leaking. I looked inside and there are no fluids present. There isnt a peep out of it. I kept trying to hear if anything happen when the thermostat went on and nothing happens. It really appears that there is no power to the unit.. but I cant find a reset button or circuit breaker on or around the unit. Just the fuses on the wall, which I replaced.
    Thanks for your response... its all such fun moving!
    President:
  • 3,433 Answers
Was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
Posted on Jul 29, 2009
  • Ned C Cook
    Ned C Cook Jul 29, 2009
    I'm sorry to say that there won't be any fluids leaking because freo (refrigerant) is a gas.. Giving this alot of thought there is no reaso, other than causing a leak, that bumping and moving a few inches for it not to work. Well, obviously there is, because it isn't. Was it working before the incident or during? The ouside unithas no resets and is hardwired to a box in close proximity with two large buss fuses. Be extrememely careful around those two. It's high voltage and cando some derious hurt on you. The circuit breaker panel on the house has two 50 amp breakers side by side. See if those are tripped. To properly reset or check those,Turn them off, wait a few minutes and turn them back on. Thehave the levers connected to each other to work as one unit.. These are also the breakers you would turn off before messing with the two buss fuses mentioned earlier.. I doubt the buss fuses are a problem, but the house circuit breakers may possibly be. Good luck
  • Ned C Cook
    Ned C Cook Aug 23, 2009
    Just following up on your A/c problem to see if you got it resolve and what was the cause. Not bumping into it I'm sure. --Ned
I have a 2 1/2 ton unit. If the outside temperature is 95 degrees. What should I expect from my unit in cooling my house.
If properly charged your unit should perform fine, having a dirty condensor at that temperature can cause problems not easily recognized.
A well insulated house should be able to maintain a 20 degree temperature difference whether its summer
or winter. No Mechanical cooling or heating involved
for at least 6-8hrs if not more.
If it never cools when it is 95 degrees outside the ambient outside temperature is not the problem.
At 95 degree out side air you should be seeing inside discharge air temperatures betwenn 48-55 degrees.
It is the load in the house that determines how long the unit will run at 95 degress.
Jun 21, 2010 | Goodman CKL24AR24 Air Conditioner
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
A/C fan is running but no cool air
Make sure the outside unit is running. If it is then you may need to get the unit charged.
May 02, 2010 | Goodman CPLT24-1 13 Air Conditioner
Heat pump not cooling
You may have a bad running capacitor on the outdoor unit. It is a round or oval can with three sets of prongs on it. Over time they can either become weak or swell due to an overload.
Aug 10, 2009 | Heating & Cooling
Goodman a/c blower runs on auto and humidity problems
Is the air cold inside? You are talking about the fan inside? Have system check for freon but more than likely, it sounds like a t'stat problem. And it's not normal for the fan to run constantly.
Jul 05, 2009 | Goodman CLQ36AR49 Air Conditioner
Blower in house runs, but compressor outside does not
Sounds like control voltage problem. Tsat mat be bad. It is hard to say without looking. Next time this happens. Have someone stands out side by the unit to see if the contactor is pulling in. When you turn the Tstat off and wait and turn it on you may be manually make the contact in the Tstat. If the fan and compressor are not running when you call for cool, Most of the time it is the control voltage. Let me know if the outside fan runs and the compressor does not. Rusty
Jun 06, 2009 | Goodman CKL42AR42 Air Conditioner
Heat pump not running
check your house circuit breakers first that should be labeled heatpump or outdoor unit
make sure it is on and or not tripped
then if you have a box outside near the outdoor unit open it up and see if there is a breaker or maybe fuses that could be blown
May 26, 2009 | Goodman CPLE24-1 Air Conditioner
Goodman PHJK048 Heat Pump Package
ok...where to start.lol ....the thermostat is just a switch.It will tell the unit to run or not run.if you measure the temp with the heatpump running,the air is warmer than 68 but it feels cool to you because your body is 98.6.The unit will run more often and for longer periods when the temperature drops outside for a few reasons.First,your house has more of a load to heat,meaning you have more heat loss because of the difference in temperatures outside and inside.Second,your heat pump pulls heat from the outside air.The colder the air outside,the less btu's for it to pull.If you have anymore questions hillbuck29@aol.com Hope this helps,Dave
Nov 10, 2008 | Goodman PHKJ048-1 Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
433 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
