Question about Denon AVR-1082 Receiver
No speaker output from television input. Other inputs (DVD, CD) work fine.
  • blueextc3221
    blueextc3221 May 11, 2010
    Have you tried another source besides the TV in the TV Input? Have you turned ON the TV RCA Output? Is the Number Output selected on the TV??
    Problem Solver:
  • 9 Answers
Check to make sure you have the TV input connections in the correct
slots. Sometimes there are two possible inputs for a TV. One being a monitor 1 and the other a monitor 2. There could also be speaker select buttons on the receiver that correspond to each.
Also check the TV audio settings to make sure the output connections are sending an audio signal, also known as external speakers.
Posted on Jul 29, 2009
Jensen Troubleshooting
be sure its in the right input/ output channel.
its always a small detail, recheck your wiring.
Oct 27, 2013 | Jensen Vm9311ts Dvd/cd In-dash Car...
BOUGHT NEW FLAT SCREEN NEED HELP HOOKINF UP DVD/VCR
1. Video Output from DVD .. and Video Input in the TV..Used your Yellow cable for Video Output... 2. Audio Output from DVD and Audio Input in DVD (if your TV have a built-in Speaker)
Red & White Cable for Audio Output..
If your DVD has its on Speaker... don't follow the step 2.
if no sound.. please see to it if your speaker of your dvd is connected.. (if not Please connect it)
Aug 19, 2011 | Televison & Video
Multi room will not play any digital input, just analog. I.e. Video 1 when analog connection plays in multi room, but optical 1, when set as input for vid 1 will not play in multi; works fine in main...
I have a Marantz 7.1 AV receiver (sr5500) and I run a 5.1 set up for home theatre and use the 2 extra channels to run a pair of outdoor stereo speakers... When I first set it up I also found I could not get a digital signal output, only analog, after reading the manual(!) I discovered that it can only output an analog signal...so I have used the phono outputs on my blu-ray player into the CD input of the AV amp and play CDs outside through this and it also outputs the optical digital signal into the AV amp through the DVD input...my iPod also plays through a dock and it's analog output to the speakers outside through another (CD-R) anolog input on the amp... Hope this helps
Dec 24, 2010 | Harman Kardon AVR 335 Receiver
I have a Toshiba D-VR16. How do I copy a VHS video onto a CD?
Just put the tape and a blank cd in and just press the Copy from the case.
Aug 10, 2010 | Toshiba Televison & Video
Adding another device to the system
Well, if analog works for you connect the CD player's analog RCA cables to the VCR inputs.
Can you imagine why you NEED to have the TV audio coming into the receiver from the TV? Are the TV's audio system or speakers superior to the audio section of every other source of TV-related programming? We hope not. Does the TV receive any programming that the receiver can not? Maybe games. I imagaine this MIGHT justify running analog TV audio back to the receiver.
Your cable box and your DVD player have both digital and analog audio outputs. The gray area is what your TV has for audio inputs. It could survive with simple RCA analog audio in from both and none to or from the receiver. Then you could watch Lo-Fi cable and DVD's without the receiver turned on.
That would free up the TV analog audio input for other things.
I imagine your DVD player is using one of the digital inputs on the receiver. If you have one each optical and coaxial audio output among your DVD and Cable Box you could place them in the two available diigital inputs.
Now, what about the CD's digital output? For stereo music you're not likely to be able to hear any difference between it and the analog input BUT it can still be connected digitally IF it has a coaxial output. Coaxial digital inputs can be shared.
Get an RCA-splitter and join the two units entering the coaxial audio input just before they enter that connection. Either will work just fine if you TURN THE OTHER ONE OFF when you want to us it.
Mar 19, 2010 | RCA RT2760 System
Old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
Aug 04, 2009 | Audio Players & Recorders
I can't get my coby DVD 937 to play sound while watching tv. It works fine while playing a DVD or CD????
there should be an input line of just audio cable hookups (one red and one white) that you have to run and an output cable from your tv audio output of just red and white. make sure the tv says output or line out and the surround sound system says input or line in
May 05, 2009 | Coby DVD-937 5.1 Channel DVD...
Need a diagram to hook my Bose CinemaT speakers. When I hook it directly to the tv no problem but can't figure out how to hookup my reciever and CD player to work also? Help Please
You'd be better off hooking the speakers to the RECEIVER'S speaker outputs, THEN hooking your TV audio output to an unused receiver input, such as AUX. The signals from your receiver cannot reach the TV; thus your CD player and radio will not play through the speakers if the speakers are hooked to the TV. All receiver INPUTS are designed to accept the same signal level; thus, you can use any input for your TV audio, such as Aux, DVD, CD, etc. Just remember which input you're using for the TV audio, and everything should work fine. Almost all receivers have an AUX input; hopefully yours also has a dedicated CD input to avoid confusion. The you simply select the AUX input to hear your TV through the speakers.
Dec 26, 2008 | Bose Cinemate Digital Home Theater System...
DVD Audio Output Stops
Hey Kelby,
I've had a similar experience where a DVD movie would be playing and suddenly my Denon would just shut off, I later discovered that my rear speaker cables were not correctly installed in the back so the reciever recognized it as a short and would just shut down. Just make sure your rear speaker cables are correctly installed (right to right and left to left and with correct positive/negative placement) and see if it still does it. If it's still happening, then I wouldn't know what it is. Good luck.
Jan 23, 2008 | Denon AVR-1803 Receiver
No output from outputs to speakers.
Usually the outputs are not fused, but you can go thur speaker white noise test and see if that works first. If it does, then outputs are probably fine, IF not then the output transistors are most likely bad. Let me know and we can try some other things thur live chat if you would like. Good luck Guru Jay
Oct 29, 2007 | Yamaha HTR-5650 Receiver
Open Questions:
Denon AVR-1082 Receiver Logo
156 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
