Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES washer won't start
Moved my Frigidaire GLTF2940ES washer to new house, hit a bump so it got jostled around. I hooked it up, and regardless of the cycle I choose, the door locks and there are a couple of clicks but it won't start. Appliance repair guy said the cycle won't start until the drain pump activates, and said I needed a new control board, which I bought and replaced--but same thing happens. I also cleaned out the pump filter in the black baffle (boot). Just a couple bobby pins and a little lint. Do I need to replace the pump? Are there other things I should try first? How can I tell if the pump needs replacing?
  • k_petre Jul 29, 2009
    How do I "apply voltage to it"?
  • k_petre Aug 01, 2009
    Replaced pump, working fine now.
  • 3,037 Answers
Applying some voltage to it should get it to run. You could always otherwise order one from the following website http://www.repairclinic.com/Appliance-Parts?s=t-GLTF2940ES-%3d%3d
The third part down is the drain pump on that link. If replacing it doesn't fix the problem, you can return the part within 30 days. A pretty good deal to those who are having trouble diagnosing the exact problem. It keeps you from wasting money on parts that don't fix the problem. Let me know how this turns out.
Benjamin
Posted on Jul 29, 2009
  • Benjamin Patri
    Benjamin Patri Jul 29, 2009
    Take some wires, hook them onto a 12 volt battery such as a car battery and to the pump and the pump should run a little bit
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Filter replacement for frigidaire gltf2940es
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire GLTF2940ES Front Load Washer
We have a Frigidaire model GLTF2940ES3 when we press the start water won t come out, it does not give any error just stays there any ideas?
first make sure the water spickets are on. plus there are screen filters where the hoses hook up. take hoses loose and make sure there is no debree.clogging them. make sure water comes out the hoses. hope its that simple.
Sep 07, 2011 | Frigidaire GLTF2940ES Front Load Washer
This washer is one year old in a new house. the cold water seems to take forever to fill - is this normal???
WEll, maybe not. Disconnect the hose and test flow there. Items to include in your ivestigation are tap washer on hose faucet, INLET screen on machine hook ups...Often the screens plug up with particulate matter....
Oct 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
Do i need to put in shipping bolts to move my washer 600 miles and if so where do they go and what size bolt do i need?
The shipping bolts protect the washer tub from getting bounced around when the washer is moved. The shipping kit should have come with your washer when you purchased it. If you have misplaced it, you can find it here http://www.repairclinic.com/SSPartDetail.aspx?s=t-GLTF2940ES-%3d%3di1170681&PartID=1170681
Hope this helps you.
Aug 31, 2010 | Frigidaire GLTF2940ES Front Load Washer
E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
